Old 11-09-2004, 09:42 PM   #1276
afm
afm's Avatar
Originally posted by au_Nightmare
don't know.
http://www.pmt-tyres.it/
They offer Kronos, Slick and Mousse
I had some PMT for my 1/8 buggy and they where great once warmed up... Looking for something to beat sorex
Fantastic rubber tires...we've been running with PMT tires for 2 years here in Peru in our only rubber class, and they have the best grip/wear/price balance of all tires tested. Best of all they have pre-mounted option, and the slicks are the best for almost all conditions. Kronos work best in very dusty low grip track conditions. Other great thing is you can choose from 40, 45, 50 and 55 shore hardness. A set of 4 pre-mounted tires imported directly from the factory costs us U$D 30.00 landed in Peru.
AFM
afm is offline   Reply With Quote
Old 11-09-2004, 09:48 PM   #1277
See this thread
http://forums.radiocontrolzone.com/s...d.php?t=160159
Now back to topic - The mighty STS Dragon engines! BWahahaha
au_Nightmare is offline   Reply With Quote
Old 11-10-2004, 12:48 AM   #1278
Send a message via ICQ to noobatron
hey guys
i've got my D5 and it's running a treat! i'm just after a rear engine bearing (the inside one). can anyone help me out with this?
noobatron is offline   Reply With Quote
Old 11-11-2004, 05:13 PM   #1279
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Default Dino
Originally posted by 20 SMOKE
Dino, have you heard from Geoff or talked to him I've tried for about a week and no answer just his voice mail
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-11-2004, 10:14 PM   #1280
JustRace's Avatar
Default Re: finally
Originally posted by Data
the modified d3 perform better than i expected (geoff can attest to that ), thank you for the mod tips. now let see how durable these engines are.
data
What mod tips? I just got a D3R from Project Zen.
JustRace is offline   Reply With Quote
Old 11-12-2004, 04:42 AM   #1281
evo1's Avatar
Default broken crankshaft.
Can anyone help me out . I need a new crank shaft and con rod for my dragon 3 port engine, where can i purchase them ?
evo1 is offline   Reply With Quote
Old 11-12-2004, 01:47 PM   #1282
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Default Re: broken crankshaft.
send an email to [email protected] they can help
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 11-13-2004, 06:09 PM   #1283
Default Take note of the kids! :)
Old 11-14-2004, 06:35 PM   #1284
20 SMOKE's Avatar
NOTHING BUT OOOH YEAH
Jamie W
Old 11-19-2004, 07:07 PM   #1285
JustRace's Avatar
Default motor question
I'm running 30% with standard head shims (.5mm) total and a number 7 plug. I had to lean the top end to about 2 1/2 before I got any performance out of the motor. Is this about right? I'm wondering if I use less shim so that I don't need to lean this far in. I've got the bottom to about 4 1/2 out.
I'm also noticing alot of fuel around the carb. Not sure if it's coming from the front bearing. I'm going to try a nova carb to see if it makes a difference. I think this is making the motor very difficult to hold a good tune and also very sensitive on the low end needle.
Any advice will be appreciated.
Old 11-19-2004, 11:27 PM   #1286
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Default Re: motor question
What is your running temp? and what is your gearing and what kind of car are you running
Ah10 is offline   Reply With Quote
Old 11-20-2004, 04:33 AM   #1287
JustRace's Avatar
Default Re: Re: motor question
Ah10,
Running temp is about 260F. It restarts easily and runs pretty good. It just seems very picky about the needle settings. A 1/16 turn on the low end makes a big difference on how the motor runs. The fuel around the base of carb and front bearing is worrying me.
I'm running a 710 with stock gearing. I've use the same car with other motors without problems. I wanted to make sure I didn't have a leak in my fuel lines and tank.
What kind of settings did you end up with your D3R?
Old 11-21-2004, 12:24 PM   #1288
Default D21b needle settings
Anyone know what the standard needle setting are for the D21B?
pixels_cs is offline   Reply With Quote
Old 11-24-2004, 07:07 PM   #1289
20 SMOKE's Avatar
Dine this had me scratching my head RDLogics pipe #62604L but I like my STS beter
Jamie W
Old 11-24-2004, 10:35 PM   #1290
Ah10's Avatar
Default Re: Re: Re: motor question
Ah10,
One thing that I found out on these D-Series engines is they like to run hotter then Nova base engine. At first I tune it to run at 200F but the performance is just not there, so I kept on trying different things like headshims, plugs, gearing, tire size and such finally lean it out and run it at 250F, from that point on the motor just came alive!
So from my personally experience, 250 is a pretty good temp on these motors (also the weather too, humidity and such)
when you are running at that kind of temperture, all the needles are very sensitive (STS motor's needles are pretty sensitive compare with nova base)
on the fuel leak, you might want to strip the engine and reassemble it, sometimes when you strip it down then reassemble it then it will solve the leaking issue!
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
