Old 10-11-2004, 09:48 AM   #1231
dameetz's Avatar
How often do you change the internal bearing for D5R? Mine has only gone through about a gallon and the crankshaft already has got play indicating the bearing has worn out. My friend has changed it twice. He said that maybe because of its smaller steel balls as compare to Nova's bearing making it less durable. Is it true?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 10-11-2004, 09:23 PM   #1232
Nitro Tech
dino.tw's Avatar
a gallon is about 3785cc.
3785 / 75 = 50.46 tanks
if you can run 6 mins in one tank of fuel
50 x 6 = 300 mins
it is about 5 hours running.
After about 5 hours hard running,you better change the front bearing. The front bearing worn out faster than the rear bearing. I will change the rear bearing each ten hours running.It also depend on how you running,hard or just for fun. Also depend on the fuel's lubricity.
dino.tw is offline   Reply With Quote
Old 10-12-2004, 10:51 AM   #1233
Send a message via ICQ to noobatron
Default best way to get engine bearings out
Hey guys,
i was wondering what the best way to get engine bearings IN and OUT was. Usually i strip down the engine leaving only the case and bearing, then put it in the oven for 10-15 mins @ 280 degrees celcius, and then pry the bearings out. Is there a better way? Does it hurt my engine heating it up this high?
any input would be much appreciated
thanx!
noobatron is offline   Reply With Quote
Old 10-12-2004, 11:40 AM   #1234
Nitro Tech
dino.tw's Avatar
Default Re: best way to get engine bearings out
Originally posted by noobatron
Hey guys,
thanx!
http://www.rctech.net/forum/attachme...&postid=644848
Old 10-12-2004, 09:38 PM   #1235
Default front bearing
heheh thanx dino, do you have the one for front bearing aswell?
Old 10-12-2004, 10:02 PM   #1236
Nitro Tech
dino.tw's Avatar
Default Re: front bearing
The same process. The front bearing is easy to be pushed out from hot crankcase.
Old 10-17-2004, 03:50 PM   #1237
AMGRacer's Avatar
Dino just wanted to tell you that I run a STS D3R on the weekend and the power from this motor is amazing. I was easily able to hang with and even beat cars equipped with NS12 motors and such. My combination was R40 + STS D3R + Nitro Shoes and I lapped the entire field except one car twice in the B final.
Awesome motor, holds its tune excellent and makes a ton of power.
AMGRacer is offline   Reply With Quote
Old 10-19-2004, 01:02 AM   #1238
Nitro Tech
dino.tw's Avatar
Thanks for your support.
Old 10-22-2004, 06:36 PM   #1239
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Default .12 Pipe
new pipe if any one want's to see it
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-22-2004, 10:27 PM   #1240
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Default Re: .12 Pipe
Looks nice
Walter Diaz
wad is offline   Reply With Quote
Old 10-23-2004, 07:10 AM   #1241
Nitro Tech
dino.tw's Avatar
New product if any one want to see it
Old 10-23-2004, 07:19 AM   #1242
Nitro Tech
dino.tw's Avatar
With this hat your car will become very stable and fast! Also protect your skin to avoid sunshine's burn. It's produced by precise CNC machine with highest technology of course 100% cotton. Wanna win? Get it now.....
Old 10-23-2004, 12:05 PM   #1243
wad
wad's Avatar
Was it approved by IFMAR??
Walter Diaz
Old 10-23-2004, 04:18 PM   #1244
20 SMOKE's Avatar
I want one I want one hahaha
Jamie W
Old 10-23-2004, 04:24 PM   #1245
20 SMOKE's Avatar
Dino the .12 pipes are outlaw, are you going to have a standerd one.
Jamie W
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
