Old 06-14-2004, 11:47 AM   #826
Data's Avatar
Originally posted by au_Nightmare
Data,
I have a D5 and thinking of a D3 (IFMAR one) hmm so you like it better hey?? why?
nightmare:
it is only a feel more than anything else. the response on the d5 i had is kind of slow but i am sure it was because of the carb. and the pipe I used (nova carb., a top end pipe with enlarged 7.2mm stinger) or maybe i just got a lemon (hey dino, you know about the lemon law in ca right ?). what is the setup on your d5? i think the setup on my d5 are all messed up and hopefully i can fix that with your setup.
on the d3 i left everything stock and ran with a rdl turbo ii pipe (enlarged 6.3mm stinger) and a kawahara header. the engine response well at bottom and mid., it accelerate fast and has an acceptable top speed (fdr was about 5:1 on 2nd with a set of 57mm tires). fuel consumption is good even with a slightly rich carb. setting. overall a nice engine at a reasonable price.
data
Data is offline   Reply With Quote
Old 06-14-2004, 01:35 PM   #827
D3 Sounds good, I would only have to guess on my needle settings but they are really strange, its something like 6 turns or 7 on LSN and maybe 3.5 on HSN. It was slightly slugish hitting 2nd till bout 7 mins into 20min final then it was going like a rocket. Weather is cold so took a bit for engine/chassis to warm I guess
The Top and pipe with larger stinger (taking away more low end) may of killed your low end torque? I am just using a THS pipe (read: Rdlogic) on LD3.
au_Nightmare is offline   Reply With Quote
Old 06-14-2004, 02:49 PM   #828
Data's Avatar
i think the threads are finer on the lsn with the sts carb. and i also notice that the engine needs a couple of minutes to warm up.
i was hoping i could shift the power to the top a little since the d5 is pretty powerful at the bottom and mid. i will mess with it again once i get the d3 done.
Old 06-14-2004, 03:11 PM   #829
Originally posted by Data
i was hoping i could shift the power to the top a little since the d5 is pretty powerful at the bottom and mid. I will mess with it again once i get the d3 done.
Maybe gear her up I just upgraded to 0.8 gears and love'em. I have made my 2nd gear even taller and the D5 pulls hard. I dont know if its my pipe or what but other engines at the club sound like they are screaming while mine is just putting around (and pulling away - well at out local club anyway hehehehe).
Old 06-14-2004, 03:36 PM   #830
Data's Avatar
maybe i should try that, but in general i don't like ratio that is too tall. ratio between 5.2 and 4.8 is perfect for the track i run at.
another reason i used the bigger stinger is i was trying to smooth out the bottom a bit. i guess either i over did it now it become really really smooth or i approch it in a wrong way. do you have any problem with the d5 that the response is not that linear ? the power just come all of a sudden.
Old 06-14-2004, 04:01 PM   #831
Yeah id try taller gears just to see how it goes..
I have not noticed the power coming on all of a sudden. Here is a thought - Maybe because I use taller gears so the power band lasts longer where if your gearing is too low it will be a sudden power surge as it passes though the power RPM then its all over?! I guess thats possible?!
Last time my friend with FW05 / Nova 5 port and myself played at netball courts, D5 and Nova where comparable (we couldnt tell winner) and my gearing is taller then his. 1st/2nd gear - 6.875/4.525 Vs 7.47/5.44 (thats ratio of engine rpm to drive axels, tyre size not included)
Old 06-14-2004, 04:32 PM   #832
Data's Avatar
do they reach top speed almost at the same time ? i would think the FW will reach top speed sooner.
will play with the gearings a bit and change the pipe. i probably messed my d5 up somehow becasue i really don't know what i am doing most of the time, but hey dino, i DEMAND a refund on the d5, regardless.
Old 06-14-2004, 05:22 PM   #833
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally posted by tallyrc
ok, the whole shimming and plug thing has got me confused again. i live in florida where it is like 100 degrees every day and i use 20% nitro, how should i shim my engine and what plug should i use???? preferably os plugs as they are common.
what motor do you have.
where in fl do you live or race
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-14-2004, 05:48 PM   #834
Both where comparable in acceleration and top speed even though gearing is pretty different. We could not tell who was faster.
I guess the D5 = torque, gear her up and let it pull the car in its power band
Old 06-14-2004, 07:10 PM   #835
jjmudd's Avatar
Default Anyone have this happen?
Was running my STS 3port mod with 30% and no head shims. I tore the motor down for a clean and rebuild and added 2 RB copper shims...motor would scream for 1 to 2 minutes and then die. The coil in the plug would be pushed all the way up and look like a little, thrust bearing sized, ball melted on to it. 4 plugs in as many minutes (mc59, O'Donnel 77, CMB 6, O.S.8). Tore the motor down again and rebuilt with the original silver shim and the two RB copper shims. I checked the play in the conrod bushing and it looks fine...what the heck is going on??? Dino???
jjmudd is offline   Reply With Quote
Old 06-14-2004, 10:16 PM   #836
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default Dino
hey Dino, I was speaking with geoff at projectzen ealier today about the new D3R, it seem to be a awesome engine. I forgot to ask him if the engine is going to be a long stroke or a short stroke engine. also do you have any pics of the new D3R?
thanks Jason
jscamry is offline   Reply With Quote
Old 06-15-2004, 12:58 AM   #837
Nitro Tech
dino.tw's Avatar
Default Re: D3
dino:
just had the d3 broken in and ran a few laps today. i think i like the d3 more than the d5. will you take my d5 back and give me another d3 ? (and don't be so predictable again this time )
data
What? What? I can't read english...I'm Chinese....
dino.tw is offline   Reply With Quote
Old 06-15-2004, 01:10 AM   #838
Nitro Tech
dino.tw's Avatar
Default Re: Anyone have this happen?
Too big compression will let the coil in the plug pushed and broken. If your engine is using normal plug,0.4mm shims with 30%nitro. If turbo plug use 0.5mm. try...try...
Old 06-15-2004, 01:15 AM   #839
Nitro Tech
dino.tw's Avatar
Default Re: Dino
thanks Jason
still 14.00 mm Stroke. I will upgrade our website soon....
Old 06-15-2004, 01:20 AM   #840
Nitro Tech
dino.tw's Avatar
It represents the igniting timing too late. So you will feel the power band like this ;
just take out 0.1mm shim and try again...
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
