Old 05-08-2004, 05:30 PM   #721
bballer's Avatar
alright, thanks that helps a lot When you say adjusting 1 hour, isn't it 1/12? Alsoc when the settings are for example 4 out, that means 4 turns (12 hours or 1 full circle) correct. This is what i have been doing and i just want to make sure
bballer
bballer is offline   Reply With Quote
Old 05-08-2004, 05:31 PM   #722
jjmudd's Avatar
Originally posted by ottoman
if you have trouble picturing 1/16 Make believe the needle is a clock and adj 1 hour at a time
Hey ottoman,
What clock do you know of that has 16 hours??!!
jjmudd is offline   Reply With Quote
Old 05-08-2004, 05:33 PM   #723
bballer's Avatar
I was wondering about that myself! lol
Thanks again for the help
Old 05-08-2004, 11:48 PM   #724
ottoman's Avatar
R/C Tech Charter Subscriber
Ha ha ... I should have said 1/16 to 1/8 turn... or the clock.. were 1 hr = 1/12th turn
ottoman is offline   Reply With Quote
Old 05-09-2004, 10:20 AM   #725
I am at high alt. in colorado and cant seem to get the temp above 200 should I try a hotter plug and if so a reg, long or short? Sorry if the answer is posted else were in the tread I got tired after the first 10 pages HA HA ! Thanx for the help.
h22ajspec is offline   Reply With Quote
Old 05-11-2004, 09:03 AM   #726
There is no reason to make your engine run hotter than 200 degrees if it is performing well.
I raced with a guy who had an RB that ran at 190 degrees and was faster than most everyone on the track.
How is your engine running?
burger is offline   Reply With Quote
Old 05-11-2004, 04:00 PM   #727
My engine runs great low to mid but bad in the high rpm range and I cant figure out if I need to lean out the high need or what. any ideas.
Old 05-11-2004, 04:23 PM   #728
Send a message via AIM to Johnnytc3
gear up
Johnnytc3 is offline   Reply With Quote
Old 05-11-2004, 05:01 PM   #729
Ok I was just running my car and noticed it runs better with little fuel in the tank and worse at full tank its a nitro tc3 with the new tank should I lengthen the fuel line and air line.
Old 05-11-2004, 07:42 PM   #730
make sure you have the newer tank, orings installed underthem, i dont know how long yours are but my pressure line and throttle line are fairly short, like 6 inches each.
Old 05-11-2004, 10:00 PM   #731
tallyrc's Avatar
it's leaning out at the end. is your car not running well when the tank is full? if so, my guess is your engine is a little rich, or your pressure line is too long.
tallyrc is offline   Reply With Quote
Old 05-16-2004, 09:07 PM   #732
gentleman81's Avatar
how many guys are happy with there sts motors. if so why, if not why? and which one do u have?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 05-16-2004, 09:18 PM   #733
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default Dino:
hey Dino. I own a D3, I was wondering what are the specs on the front bearing for the D3? My bearing seems to be leaking, I also am using 3 of the thin washers(from crc ) to prectect the front bearing..
thanks Jason
jscamry is offline   Reply With Quote
Old 05-16-2004, 10:15 PM   #734
jjmudd's Avatar
gentleman81,
My STS RS3 Non-Turbo motor just TQ'ed and won the mains in todays club racing, www.edmontonrc.com . The motor is plenty fast, the only trouble I have had is keeping it idling when in for fuel stops...pull in stop and motor dies...re-fires at once and stays lit untill the next fuel stop!! Have tried different heat ranges of plugs and various shim hights...nothing yet. I feel it is solvable with a little more work...maybe bottom too rich and loading??? Dino...sugestions. Other than the tuning problem...which is probably me more than the motor, it runs with all the motors in our club, OS TR's, Rossi Pixi's, Nova Rossi's. The only motor, at our track that is quicker is a M.S. Nova Mega and I think if I were to get the bottom sorted it would be a different story. For the $$$ best bang for the buck...imho.
Old 05-17-2004, 01:07 AM   #735
Default Need any help?
Look who pushed me out of the way to work on my STS Dragon
au_Nightmare is offline   Reply With Quote
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
