STS engines
Old 01-29-2004, 11:12 PM
  #286
jfc_tech's Avatar
ooopppss..silly me. sorry.
jfc_tech is offline
Old 01-30-2004, 01:54 AM
  #287
Fisher890's Avatar
Dinoguy woke up this morning with the new ConRod....... It Sang a new Song to me Today it went BG BG BG. It was too fast to get the lin in Bling. It likes alot more needle settings now and is sick fast. Now I Know STS power. Spending More time on Break in gets me less time Breaking .Very nice job Dino and Thank you again! Still not going for race settings it is very happy running at 220F-225F.My next step will be gearing for the tracks here. Does anyone know of some So Cal. tracks with Novice/Sportsman nitro classes running races this weekend?
Fisher890 is offline
Old 01-31-2004, 01:44 AM
  #288
Fisher890's Avatar
Default Re: D3 better for larger or smaller tracks
Originally posted by jscamry
I was wondering is the D3 ment for a larger size track that has about 100-200ft straights or smaller tracks?
thanks Jason
Check your PM Jason
Old 01-31-2004, 11:34 AM
  #289
ruD
Hi Dino,
I've finally got a STS D5 after hearing so many good feedback bout it, will be runnin in soon. Just a question here regarding the shimming, since its optimised for 25-30%, do i still need to add a 0.1mm shim when runnin in with 25% nitro?
Regards....
p/s
Mr. Sunny Hee sent his regards as well.
ruD is offline
Old 01-31-2004, 12:45 PM
  #290
(delete)
au_Nightmare is offline
Old 01-31-2004, 01:02 PM
  #291
20 SMOKE's Avatar
Trader Rating: 102 (100%+)
Hey Fisher I race at the same track jason does and i have the D3 that might be why he asked that question,whats your opinion or any ones opinion on it for large tracks.
20 SMOKE is offline
Old 01-31-2004, 01:27 PM
  #292
Fisher890's Avatar
Mine seems to be craving lower gears for long straights.
Old 02-01-2004, 07:32 PM
  #293
Default STS D5 Factory Settings..
Hi,
What are the factory settings for STS D5 engine for low and high end? Thank you..
STSDRVR is offline
Old 02-01-2004, 09:24 PM
  #294
Nitro Tech
dino.tw's Avatar
Originally posted by ruD
Hi Dino,
I've finally got a STS D5 after hearing so many good feedback about it, will be runnin in soon. Just a question here regarding the shimming, since its optimised for 25-30%, do i still need to add a 0.1mm shim when runnin in with 25% nitro?
Regards....
p/s
Hi ruD,
Thanks for your support.
The D5 coming with total 0.5mm shims. It is optimized for 25-30% Nitro using. I suggest you to use low %(5-15%) nitro to break-in your engine. It will be good for conrod and crankpin. The D5 needs about 2L to break in.
Regards,
Dino
dino.tw is offline
Old 02-01-2004, 09:34 PM
  #295
Nitro Tech
dino.tw's Avatar
If you use 16T and 19T pinion gears,change them to 17T and 20T.If the top end is not enough,I will change gear first.
dino.tw is offline
Old 02-01-2004, 09:36 PM
  #296
Dino, in other thread I read you have problem with LD3 pro and stock pipe. This is the pipe I have, what was the problem ? (I am still breaking in D5 engine so have not hit problem yet)
Old 02-01-2004, 09:37 PM
  #297
Nitro Tech
dino.tw's Avatar
Default Re: STS D5 Factory Settings..
Originally posted by STSDRVR
Hi,
Mid Range needle - Flush with the housing.
Low Speed needle - 4 Turns out.
High Speed needle - 4 Turns out.
dino.tw is offline
Old 02-01-2004, 09:54 PM
  #298
Nitro Tech
dino.tw's Avatar
If you feel it work OK,that is fine.
Because this stock pipe is too long,so you will feel more less top end.
Most of people will lean the main needle when they feel the engine is not fast enough. And maybe damage their engine due to not enough lubricity.If you want more high end,I suggest you RD LOGIC #61250/61255
dino.tw is offline
Old 02-01-2004, 10:00 PM
  #299
Dino, Thanks for reply.
I'll try avoid falling in to the lean out trap and look at getting new pipe.
Old 02-01-2004, 10:15 PM
  #300
kitracer's Avatar
"Done lean the main needle too much!"
I tested this engine on the weekend and compared to Nova NSR, it have just as good, if not better top end.
I was using a Nova 5TF but found lacked little bit of top, so I switched to a 6TF. The top end came alive right away (and kicked a lot of butt ) without lossing noticable torque
I used a 5m stinger and 25% nitro.
kitracer is offline
