Old 09-08-2011, 03:30 PM   #2746
Trader Rating: 24 (100%+)
Originally Posted by Bundy_Bear View Post
Hi
Just wondered if anyone had any tips to get this motor to run on the AT Racing Platinum 16% nitro racing fuel. I have just finished running it in and first time on the track it would do half a lap and then die.
I am using a Novarossi medium plug...
I noticed idle would increase in rpm and going richer on LSN didn't seem to make any difference. I previously used a cheaper fuel from my local hobby store in my picco, maybe I am not advanced tuner to use race fuel
Thanks in advance
Andrew
you my have a leak check the back plate the s12x3 i had was alittle loose
and that was it ran great at 250f.
RANDY SMOOTH is offline   Reply With Quote
Old 09-08-2011, 04:08 PM   #2747
Trader Rating: 15 (100%+)
Default engine
Hi
Thanks in advance
Andrew
Check all the screw and fuel line. Sounds to me like you may also need a hotter plug, this fuel may have a different oil content then the last stuff you used it looks pretty heavy on oil at 15%. Richen the top an bottom up and start all over tuning the top and the work on the bottom,
mdhyams is offline   Reply With Quote
Old 09-12-2011, 05:58 PM   #2748
Bundy_Bear's Avatar
I haven't changed the head shims to suit 16% nitro yet so i am not sure if this will cause any issues. I also found the HSN to be a little loose from me adjusting it to bring the fuel nipple around.
Hope to be able to try it again soon
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 09-12-2011, 06:57 PM   #2749
Default engine
Andrew
At 16% nitro you should not have to change the shim. Normally the shims are set for 20%. Basically here is the rule, .1 shim for every 10% nitro, So at 20% you need .2 shims, or 30% at .3 shims.
As far as the fuel nipple you canput a little thread locker on it and that will fix that problem.
Mike
Team STS
Old 09-12-2011, 07:07 PM   #2750
Mike
Team STS
how is the new 833 engine
Old 09-12-2011, 07:15 PM   #2751
Default 833
I have not tried the 833 yet, by the looks great.
Old 09-12-2011, 07:38 PM   #2752
Bundy_Bear's Avatar
Mike
Team STS
Hi
Thank you, i will check when i get home tonight, from memory it had three shims under the head.
I found this on the STS website:
- Under 20% Nitro 0.3 mm
So I will see what the go is...
Andrew
MissMooRC Racing
Old 09-12-2011, 07:51 PM   #2753
Default engines
Hi
Andrew
It depends on the thickness of the shims.
This was the standard for all engines.
Mike
Old 09-13-2011, 06:49 AM   #2754
Bundy_Bear's Avatar
Mike
Hi Mike
Thanks for your assistance, I measured them tonight and it was over 0.30mm so I removed the copper shim and it is now right as per manual. I also have installed a new plug just to giver her a full service....
Have noticed HSN is tight to turn, my picco and SH engines are ot like this, might get another STS Carb just in case.
Andrew
MissMooRC Racing
Old 09-13-2011, 09:12 AM   #2755
Default motor
Hi Mike
Andrew
The reason why the HSN is tight, could because of the o-ring.
That is normally a good thing.
Mike
Old 09-13-2011, 06:31 PM   #2756
Bundy_Bear's Avatar
Mike
Thank you for clarifying this for me, i hope to track test it again soon
Andrew
MissMooRC Racing
Old 09-15-2011, 02:15 AM   #2757
Bundy_Bear's Avatar
Default LX12S3 Update
Hi
Just wanted to let everyone know my engine is now running alot better, thanks to everyone who assisted and thanks STS.
Andrew
MissMooRC Racing
Old 09-15-2011, 07:34 AM   #2758
Default engine
Great glad I could help.
Old 09-22-2011, 05:29 PM   #2759
Thumbs up 833
i just got my sts 833 and opened it up WOOOOW man they did a great job on this one. looking to break it in this weekend has anyone tryed the 853 3port and is the 833 the short storke and the 853 the long storke
Old 09-23-2011, 01:57 AM   #2760
stswayne's Avatar
There two engines are long stroke.
stswayne is offline   Reply With Quote
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
