Old 05-02-2008, 11:42 PM   #2611
jameslow's Avatar
ok guys... my engine is running gd now! But would like to know what could be the reason of having alot of smoke coming out of the pipe?
The engine meet it require speed and the temp is about 100 + - degree C evrything is fine like the compression, plug condition......... but just a lot of smoke is coming out of the pipe! LOL!!!
Waiting!
jameslow is offline   Reply With Quote
Old 05-03-2008, 01:50 AM   #2612
keavze's Avatar
oil content abit high in the nitro...about 8% is best i heard.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 05-17-2008, 07:07 AM   #2613
jameslow's Avatar
what causes the crank shaft pin to shear off? as i hear STS got a lot of the crank shaft having this problem!
Waiting!
Old 05-17-2008, 10:38 AM   #2614
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
heat, but that was with the first version of the D3r
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-17-2008, 11:24 AM   #2615
charlesd's Avatar
Does anyone have a review of the new sts S12X3 engine? i ran a d3r a few years ago and it was pretty good.
charlesd is offline   Reply With Quote
Old 05-17-2008, 06:30 PM   #2616
jameslow's Avatar
hmm..... i broken my d12ex crank lei....not the d3r.... but my engine temp at that time of running should be ok n lots of smoke is coming out of the exhaust...lolx
Waiting!
Old 05-30-2008, 04:47 PM   #2617
Trader Rating: 44 (100%+)
hello guys i've decided to rebuild my sts engine and i was wondering does anyone know the correct bearing sizes for the front and rear.if i can't find ill use stockers but i'd prefer ceramics as the stockers don't seem to do the job
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 05-30-2008, 10:03 PM   #2618
slow supra's Avatar
Trader Rating: 150 (100%+)
Here you go. From STS site:
Q: Would you mind telling me the Front and Rear Bearing dimensions?
A: Front Bearing #607 (7mm X 19mm X 6mm)
.12 Main Bearing #6801 (12mm X 21mm X 5mm)
.21-.30 Main Bearing #2514 (14mm X 25mm X 6mm)
Too many cars and not enough time!!! Let's keep havering fun.
Now: Z01-B SG (2), Revo brushless (my Dogs chase car!) OS Speed, Ninja, EB Mods
Coming soon: Who Knows. I'm Nuts lol
Had: Too many to count!
slow supra is offline   Reply With Quote
Old 05-31-2008, 04:15 PM   #2619
beta bob's Avatar
Trader Rating: 2 (75%+)
I have a STS RS3.12 engine it is only about two years old and has only been used in about 15 races and then i went to electric and i decided to go back to nitro and was wondering if the engine is still any good? i had stored it properly and the engine looks almost as good as new.
Team Terribles---------2009 post of the year
"Cant you read Mopar???He said that he drives a T-max 2.5!!!!"
Spec classes are for communist
beta bob is offline   Reply With Quote
Old 05-31-2008, 05:28 PM   #2620
wingracer's Avatar
Trader Rating: 24 (100%+)
Crank pins don't break from anything you could do wrong. They only break if from either bad design, bad materials or bad manufacturing.
wingracer is offline   Reply With Quote
Old 06-03-2008, 09:47 PM   #2621
Default STS .12 case bores
Has anyone out there noticed on their new .12 size engine that the bore between the two engine bearings are not in line with the bearings themselves? If you're not paying attention it just feels like the pinch in the cylinder. Be careful fellas!
I had purchased a D3R that was misaligned. One of my buddies bought a D5R, who got the engine from another store, had the same thing. Take a look on the crank near the counter weight and you'll see rubbing marks in the steel from the aluminum case.
lurchsum69 is offline   Reply With Quote
Old 06-03-2008, 10:18 PM   #2622
CurveTracer's Avatar
When I switched to an RDL Turbo II pipe which is a less restrictive pipe the engine delivered more power. The smoke output is now a stream on initial acceleration. The power output is impressive. I always used Byron's fuel.
What brand of fuel are you using?
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 06-05-2008, 06:20 PM   #2623
wheelhead's Avatar
Send a message via AIM to wheelhead Send a message via Yahoo to wheelhead
Was wondering witch kind of plug you are running? OS,Mcoy ect. Got one of these engine in a trade and looking for some plugs for it.
CRT.5
STS .12RS 3port
Ofna High Down Force Wing/Yellow
12mm Rear Shocks/Drilled
http://grandwoodsrc.com/
wheelhead is offline   Reply With Quote
Old 06-05-2008, 07:24 PM   #2624
20 SMOKE's Avatar
I've ran an os but always went back to a nova
Jamie W
Old 06-05-2008, 08:30 PM   #2625
jameslow's Avatar
Well... im using the skyline pipe with 16% sidewinder fuel and 0.3mm shim.
Right now im using the novarossi carb! Going to try back the stock sts carb and see any much diff!
Waiting!
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
