Old 01-20-2004, 02:55 PM   #241
Corse-R's Avatar
Originally posted by tonimccloud
one of the broken engines was in Mallorca (20 degrees more or less). Maybe it was a coincidence, maybe not (the engines broke in Madrid, Mallorca, Valladolid...different places separated with a lot of kilometres and very different temperatures)
Toni:
Different temperatures, locations, etc... Seems that common denominator could be the same origin (Rc Mushroom or other HK shops???)
Probably was a faulty batch. If not, much people will complain about broken crankshafts. And the difference in temperatures makes me think about this.
Have one engine of those, modified it and had survived.... to 5 litres of fuel and I can assure you that's a real screamer (love how whines at the end of the ARCA track).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-20-2004, 06:41 PM   #242
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
is the inlet to the block for the carb 5.5mm or is the air filter 5.5mm just want to know if any one changed card to a bigger size. will the d5 carb fit d3
20 SMOKE is offline   Reply With Quote
Old 01-20-2004, 09:34 PM   #243
Nitro Tech
dino.tw's Avatar
Was that crank modified by anyone? If so it could have been weakened
There are 2 of them, these two still have the crankshaft in one piece
what will be the engine running temp?
The new generation of engine is being developed in Taiwan which is tropical country climate, we have not tested the engine at different climate countries. We do want to hear feedback and running result to further improve our products.
Please help to inform the racers who have problem with our engine that they can send the engine to our distributor for checking. If there is not any abnormal sign like hard wearing and overheat,our distributor will return them to us. We will replace a new engine for them if the engine problem is not due to mis-use or abuse.
We are only responsible for our distributor,so please don't send them back to STS directly.
Sincerely,
Dino
dino.tw is offline   Reply With Quote
Old 01-20-2004, 09:46 PM   #244
AMGRacer's Avatar
Sincerely,
Dino
Holy smoke!! This is great customer service from STS!!
AMGRacer is offline   Reply With Quote
Old 01-21-2004, 01:02 AM   #245
Hi.
The broken crankshaft in the photo is mine. As Toni said, there are several engines broken around the country, so we think that the problem isn't the air temp.
Dino... thanks a lot for your answer, but we have another "problem".... the engines was acquired in Hong Kong, in rc-mushroom. I think that is not very just that we send the engines to our local distributor.... what do you think about?.
Thanks a lot.
Joaquin.
joaquin_zero is offline   Reply With Quote
Old 01-21-2004, 01:26 AM   #246
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default Modellor
Hey: I wonder where you got that cool avatar of your co. name
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-21-2004, 01:28 AM   #247
Default avatars
The only thing is its too large to post as an avatar....heres mine
Old 01-21-2004, 09:25 AM   #248
Nitro Tech
dino.tw's Avatar
Originally posted by joaquin_zero
Hi.
Thanks a lot.
Joaquin.
You got PM.
Old 01-21-2004, 12:13 PM   #249
EdwardN's Avatar
Default Re: Re: crankshafts broken
Originally posted by au_Nightmare
Ouch I currently have STS D3 in shopping basket with rc-muchroom.. Might wait for a reply on this one from STS first
(image from below link in quote)
It seems for me the hardening process was choosen not right for this aplication-looks to "dry" for me. They hardened to much all the way through.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 01-22-2004, 07:58 AM   #250
Nitro Tech
dino.tw's Avatar
Default Re: Re: Re: crankshafts broken
The real reason is that they feel the high speed is not enough,so just lean it till the lubricity is not enough.This engine is being developed in Taiwan and most of the Taiwanese tracks have only 60 meter backstraight. So we rather more torque than more rpm. This event let me think about maybe we should product two types engine. One is super torque another is super high rpm. The other way is install VTEC system on nitro engine.
Old 01-22-2004, 11:40 AM   #251
Dino, Just need a rev limiter with big red light..
Gearing (one of the most important things IMO) seems to be overlooked by a lot of people or is it just not spoken about much in the forums??
au_Nightmare is offline   Reply With Quote
Old 01-22-2004, 11:57 AM   #252
B
Default Re: Re: Re: Re: crankshafts broken
I would like to see that!
Add oil Dino!
B is offline   Reply With Quote
Old 01-22-2004, 12:39 PM   #253
Data's Avatar
i want to ask you what you think about the two types of engine characterstics. which type of engine do you think is easier to adjust for different track size (gearing and tuning) and which type is easier to drive ?
Data is offline   Reply With Quote
Old 01-22-2004, 01:07 PM   #254
Corse-R's Avatar
Hehehe.... I'm just remembering a post of mine some days ago (probably two or three pages before) 'suggesting' you an 'European' version of the dragon.... More suited to the larger tracks we have there (we talked by MSN of mods to alleviate the hungriness for high end of those guys.
Got any answer from your boss regarding that ones?
Cheers,
Corse-R
Old 01-22-2004, 02:04 PM   #255
speedxl's Avatar
R/C Tech Charter Subscriber
if the motor produces a ton of tourqe then gear taller because the motor will pull it .
no reason to make different motors!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
