Old 05-14-2006, 12:45 PM   #2311
onnetz's Avatar
good luck to both of you.. I will take my wd-40 over nothing any day...
onnetz is offline   Reply With Quote
Old 05-14-2006, 01:22 PM   #2312
Tabush,
Nice buggy - Just don't scratch that pretty green head
au_Nightmare is offline   Reply With Quote
Old 05-14-2006, 05:09 PM   #2313
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Thanks, i will try to not scratch it
cya !,
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 05-22-2006, 11:36 AM   #2314
Tabushi's Avatar
After 5 tanks of break-inn here are a couple of videos of my STS .21T on the Jammin FTE (first time i get a buggy on my hands) ... i love the way the STS did on the track (being built) :
- Video 01 : http://images.domino.org/d/57077-1/2...cha_01_LBR.wmv
- Video 02 : http://images.domino.org/d/57080-1/2...cha_02_LBR.wmv
- Video 03 : http://images.domino.org/d/57083-1/2...cha_03_LBR.wmv
- Video 04 : http://images.domino.org/d/57086-1/2...cha_04_LBR.wmv
And the best of all, the engine still have more power available, cause on thats videos the max temp was 97C wich its about 205F ...
Old 05-22-2006, 07:09 PM   #2315
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Dont use WD-40 with engines that have epoxy in the crank (pressure pack cans that is). The propellant in the can is what eats the epoxy and causes problems. Every engine that i have had with the epoxy in the crank has mentioned in the manual not to use spray canned oils as after run, i am surprised that STS doesnt have the same warning.
Cheers Daniel
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 05-22-2006, 08:24 PM   #2316
Tabushi's Avatar
Cheers Daniel
So with the all-in-one WD40 oil is not a problem ?
thanks,
Old 05-23-2006, 01:54 AM   #2317
Slo-MTX4's Avatar
All i use is either singer sewing machine oil or 3-in-1/all-in-1. I would imagine that if you brought the non pressure pack WD-40 that it would also be gine to use.
Cheers Daniel
Old 05-23-2006, 02:11 AM   #2318
Tabushi, Great vids !
I dont have a DX manual to check so I dont know what it says, the 3 manuals I do have state:
AFTER RUN: It is recommended the use of rcengine after run oil to
keep internal moving parts of the engine lubricated. After-run oil
helps for an easy start next time, protects your ball bearings and
extends your engines life. After run oil can be applied via the throttle
body or glow-plug hole. Ensure the areas are absolutely clean before
you remove engine components, enter of debris into the engine is
harmful.
Maybe the epoxy engine manuals are different? (my guess they are not)
and some info i just found with google re: wd-40
http://yarchive.net/chem/wd40.html
The WD stands for Water Displacing. I haven't analysed it,
( not commonly sold here ) but somebody ( Professor Toraki? )
squirted some down a GC/MS and confirmed the solvent was
boiling around 150-200C and only contained a minor % of
aromatics, which means it is either a narrow boiling range
kerosine fraction, or a special narrow boiling range solvent
like low aromatics white spirits.
I've analysed a similar product, and it was around 80%
kerosine, 10% acidless tallow oil, and 10% lubricating
oil light base gade - with some additional antioxidants
added to improve durability. When the composition of
WD-40 last came up in sci.chem, I wasn't sure if it was a
water displacing solvent only, but subsequently there
has been a long discussion about the film left behind in
some rec.* groups - which is why it should not be used as
a lubricant, the film is only a temporary corrosion protective
layer.
That would make WD-40 like the formulation above.
The kerosine is the solvent, the tallow oil and lubricating
base grade provide the means for the fluid to displace
water from surfaces and, when the kerosine has evaporated,
leave a thin, protective film on the surface that provides
temporary corrision protection. It is possible that it may
have some solid lubricant in it ( PTFE,Graphite,MoS2 ),
but I suspect there would not be enough to provide any
useful lubrication - and thus should not be used to wash
"proper lubricants" off bearing surfaces, chains etc..
Note that the light lubricant base grade is just the vacuum
distilled, high boiling, hydrocarbon fraction used in light
lubricants, but has minimal lubrication properties ( until all
the Extreme Pressure and other compounds are added ) other
than those conferred by the viscosity. It is not a "lubricant",
just a base grade.
So, in summary, it is a water-displacing formulation which
deposits a film that provides temporary corrosion protection
( temporary usually means days to months, depending on the
environment). The 40 is supposed to mean that it was the
40th formulation evaluated - not certain if true or not.
Now back to "It is recommended the use of rcengine after run oil to keep internal moving parts of the engine lubricated.", "which is why it should not be used as a lubricant" and "it is a water-displacing formulation which deposits a film that provides temporary corrosion protection ( temporary usually means days to months"
But everyone has their own snake oil they swear by, if it works for you good luck I say!
Old 05-30-2006, 01:16 AM   #2319
moparsrule's Avatar
Does anyone else on here run the turbo .21 other then me and pato, mines having a few problems.
moparsrule is offline   Reply With Quote
Old 05-30-2006, 06:25 AM   #2320
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
D21R or D21T?
Artificial-I is offline   Reply With Quote
Old 05-30-2006, 07:14 PM   #2321
Tabushi's Avatar
Hi guys,
Take a look at my article about my debut on 1/8 buggy racing at the Mexican Nationals this last weekend with the STS .21 T + STS pipe :
http://www.rctech.net/forum/showthread.php?t=115990
cya !
Old 05-31-2006, 04:31 AM   #2322
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Originally Posted by Tabushi
Hi guys,
cya !
congratulation Tabushi. well done on yer 1st buggy debut with Jammin + STS.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 06-02-2006, 10:48 PM   #2323
Tabushi's Avatar
I would like to know any other experience on the STS .21T engine ?. Some guy on other forum sent me a private message telling me forget about STS, that i will get good engine just for 1 1/2 or 2 gallons and then will start to fail bearings and other internals ...
Any comment ?
Old 06-02-2006, 11:51 PM   #2324
Tabushi,
My first .12 was a STS (she lasted the yards for sure), my 2nd was a Nova, the next 3 engines I purchased where STS (2 x .12 & 1 x .21).
I am not linked to STS in any way, I just think they are great bang for buck engines & I pay retail prices as any other normal person does. Someone somewhere has has a bad experience with every brand engine. I too have had problems - but found the fault to be the fuel, not the engine.
Maybe the green eye monster sometimes comes out when people have paid much more for a engine that does not go as hard.
I would love to get my hands on a Team engine but I have a D3R and D5R to wear out so it wont be for some time. It would prolly only get me into trouble anyway
Old 06-03-2006, 07:21 AM   #2325
PAto:
Bearing failure is mostly due to impropre care of the engine. If you see closely and search inf. you will notice that most bearing are made on the same factory with the same standards. Just remember to use pleanty of a goof AR oil.
I received your PM , On the videos look great.
I have the B edition and also runs great.
Edgar Millenium is offline   Reply With Quote
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
