Old 04-21-2006, 02:59 AM   #2206
ChickenLips's Avatar
I just bought one, should arrive next week
Lets see how it goes in my V-One Evo
ChickenLips is offline   Reply With Quote
Old 04-21-2006, 03:02 AM   #2207
One more question, can you use the sleeve/piston from a D3R
Old 04-21-2006, 03:05 AM   #2208
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Yes, it is the same replacement part.
Artificial-I is offline   Reply With Quote
Old 04-21-2006, 03:10 AM   #2209
Thanks for the help AI
Old 04-23-2006, 10:38 PM   #2210
Originally Posted by Tabushi
XING XING, i know that ... but even with that i will give a try on the STS .21 Team Edition ...
I was racing onroad for 5 1/2 years till last christmass and for 1 1/2 i raced STS engines and it gave me nothing but great moments, so i really hope to receive the same from the Buggy green head engine ...
cya !
ok i just let people know, coz it a bit misleading to call it a "team engine"
all the top manufactureres (OS RB, NOVA etc) have slightly different engines for their team drivers, but they dont call their production engines as "team" engine.
XingXing is offline   Reply With Quote
Old 04-23-2006, 11:35 PM   #2211
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
I think that its a basic information Xin Xin ... i would like to see some day a pro pilot flying on the track with the same engine you can buy at the hobby shop
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-24-2006, 01:50 AM   #2212
nothing wrong with that but
like i said it MISLEADING from my point of view for sts to name it team engine
Old 04-25-2006, 03:35 PM   #2213
Tabushi's Avatar
Anyone knows which kind of glow plug uses the STS .21 Team Edition ?. Its OS like or Novarossi like ?, shor or long body ?
Old 04-25-2006, 04:26 PM   #2214
Moderator
Turbo Glow-Plug , STS usually prefers a warmer plug. I like to use RB # 7 , Its like the nova # 7 or ODO 77T.
Old 04-27-2006, 05:37 PM   #2215
onnetz's Avatar
anyone else running a d12x with the vr12 pipe?
I can't seem to get the low end just right with this pipe..
about a 1/3 up through the rpm range its like a slingshot. and you better be ready for it because this engne brings it...
at first I thought it was running lean on the low end because there wasn't much smoke until it hits that power band.. richened the low end and it became worse..
I had a ths pipe and it was alot more linear through the rpm range...
onnetz is offline   Reply With Quote
Old 04-27-2006, 05:45 PM   #2216
Moderator
What plug are you running?
I try to get my motors to idle about 40 seconds before they load up and die.
You can do the pinch method as well on the fuel line and if the rpms raise up and the motor dies within 3 seconds its too lean. If it takes awhile to raise up it could be too lean.
You want to get your motor fully cleared out and up to full operating temps before attempting those tests so you know its race tuned and not cold. Cold motors will run rich , hot motors will lean out.
If your on a track just take a lap or two at full tilt , bring it in and perform those tests. Another thing to try if this all fails , gear down 1 tooth on the pinion 1st gear. This can really waken up the low-end.
Old 04-27-2006, 06:07 PM   #2217
onnetz's Avatar
the plug is an odonnell med #77t.....
I did do the pinch test and seemed about right..
now that you mentioned gearing, I'm thinking it could be a combo of that and clutch engagement.. it engages at pretty low rpms, add that to tall gearing and it probably exaggerates the power curve..
I'll try some different settings on the clutch and see how it goes....
speaking of clutches, I like the mugen clutch alot better than the r40's.
Old 04-27-2006, 06:18 PM   #2218
Tabushi's Avatar
Hi guys,
I have access to the Sure Fire plugs from racer edge ... to use on my STS .21T ... enyone knows if they fit right ??
thanks,
Old 04-27-2006, 07:38 PM   #2219
Moderator
Tabushi,
The STS 21T takes turbo plug. Thats it.
As for racers edge glow plug. I wouldnt run one cause im sure the quality is not the best compared to the larger more respected companies , but if they make them in turbo plug you can try it.
If you want a good plug for your high tweaked Team motor: HPI Turbo Plug , LRP Turbo Plug , RB Turbo Plug , Novarossi Turbo Plug , Odonnel Turbo Plug are quality plugs that Ive looked into. As for OS Glow-Plugs I dont like them as when you loose the coil it can cause damage to the motor , the rest I havent dealt with that but Im pretty sure the RB wire filament if it blows out it doesnt seem to cause damage as it passes through or disintegrates.
Reason why I like RB plug.
Old 04-27-2006, 08:50 PM   #2220
Tabushi's Avatar
Tabushi,
Thanks man, but on Novarossis Plugs they have a LONG and SHORT classes, so which one can i take for the STS ?
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
