Old 08-10-2005, 04:33 PM   #1891
::TEAM SRGS::'s Avatar
Talking The aluminum venturis
Originally Posted by dino.tw
The aluminum venturis is made by CNC machine. Now we have a lot 5.4mm venturis.We also have some 5.0mm venturis that you can grind it to the perfect size that you need.You can ask P.K. to order for you.
Hi dino l just pick up a D3R and l have a D3 were can l get a aluminum venturis
that would be a lot of help
thanks ross
Nikon D300
Olyumps E20
nikon lens
28mm
185mm
300mm
::TEAM SRGS:: is offline   Reply With Quote
Old 08-15-2005, 03:00 AM   #1892
nsxshogun's Avatar
Send a message via AIM to nsxshogun
I'm having some troubles with running the white lightning in hawaii. I put 2 copper shims and another silver shim including the one already there. But my problem is when I get on the throttle and go ful throttle the engine stutters and sounds like its to lean. I'm gonna reset it back to stock settings and try from there.
nsxshogun is offline   Reply With Quote
Old 08-15-2005, 06:26 PM   #1893
nsxshogun's Avatar
Hmmm I switched back to a hotter plug from my cold one and it worked perfectly.
Old 08-15-2005, 06:33 PM   #1894
Hesky's Avatar
hum, I was actually thinking you might have needed to advance the ignition point a little with a hotter plug, but I wasnt sure.
guess thats what you needed to do then
Hesky is offline   Reply With Quote
Old 08-22-2005, 10:04 AM   #1895
Where can i get the d3r or d5r in the asia or oceania region?
Tiger
tiger266 is offline   Reply With Quote
Old 08-22-2005, 07:08 PM   #1896
nsxshogun's Avatar
Having trouble with my motor. It seems to be leaning it self out as I pull back the throttle. I'm thinking air leak. Gonna seal everything off tonight.
Old 08-22-2005, 11:34 PM   #1897
Nitro Tech
dino.tw's Avatar
Check the o-ring of mid-range sprayer.
dino.tw is offline   Reply With Quote
Old 08-23-2005, 04:47 PM   #1898
nsxshogun's Avatar
I'd have to take the needle out to do that right?
Old 08-24-2005, 01:42 AM   #1899
Nitro Tech
dino.tw's Avatar
yes! take the needle out and check the 2 o-rings.
Old 08-24-2005, 06:09 PM   #1900
nsxshogun's Avatar
Is there any tricks to making that needle come out. I was screwin that thing for a good 3min before I noticed.... It ain't goin no where.
Old 08-24-2005, 06:24 PM   #1901
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
it will come out after the threads are all the way out all you are doing is spining the needlle in the o ring
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-24-2005, 07:15 PM   #1902
ChickenLips's Avatar
Got some newbie questions for you guys.
I just bought a D5R with the STS oulaw pipe
What fuel would you recomend?
What plug?
Can the 3 port sleeve piston be used or can only it only be the 5 port, spose the crank is different as well.
BTW it's in a V-One RR
ChickenLips is offline   Reply With Quote
Old 08-24-2005, 07:41 PM   #1903
JustRace's Avatar
At this point it's already out of the threads. Take a pair of plier and pull it out.
JustRace is offline   Reply With Quote
Old 08-24-2005, 07:59 PM   #1904
rge63's Avatar
Cool
What plug?
Most fuels are fine 20% to 30% nitro
The race fuels have only have 10% oil... regular fuels have 12%oil.. Use the 12% and maybe even add some castors..
Myself I use a home brew of 30%nitro 12% synthethic and 4% castors
I have put a non-turbo head button on mine...As for plug I am using a mccoy #8 as of now because that is about all I can find right now..I prefer a nova rossi #7 (6,7,8 nova rossi seem to work well)
Some one else will have to recomend a turbo plug????
The sleeve should fit fine(quote me if I wrong on that)
The crank is different but only on inside diameter. And that is the only difference I think...Everything 3port should interchange..
After you get it broke in!!! these engines dont like to be loaded up... they like to stay on the pipe.
it will run hot if not geared right.. Good luck
rge63 is offline   Reply With Quote
Old 08-24-2005, 08:08 PM   #1905
nsxshogun's Avatar
Got it out a few min ago. I see one ORing on the needle. If theres another supposed to be connected which size is it. Also I need a head buttonn
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
