STS engines
#1576
AFM
Thanks for the answer,but I will probably buy it from mushroom because their price is very good. The brazilian dealer will not beat their price.
I would like to know who perform the modification on the engine for mushroom.
Best regards
Eduardo
Best regards
Eduardo
#1577
Originally posted by eduardo_garcia
AFM
Best regards
Eduardo
AFM
Best regards
Eduardo
#1578
STS21 onroad
Dino, the sts 21 onroad is being tested. when will it go the market ?
#1579
STS D5R
Finally had done some runs with this engine. For the $$$, its absolutely great value. However, in order to extract the maximum performance from this engine it will be necessary to polish the crankshaft. I noticed the crankshaft is slightly more than 11mm when measured with a micrometer, this may caused the crankshaft to grind against the crankcase and hence the low end problem experienced by many users. However. once its polished the performance is on par if not better than the italian mills
Rgds
Rgds
#1580
Re: STS D5R
Rgds
Rgds
#1581
Re: Re: STS D5R
Originally posted by wangcc61
And also retard the crankshaft timing. So the intake closes at 65 degree ATDC. Then, the engine will have more top end, will run cooler, but will have less bottom torque. Good for mid to big size track....
#1582
Re: Re: Re: STS D5R
Originally posted by revzalot
How do you retard the timing?
#1583
Re: Re: Re: STS D5R
#1584
Re: Re: Re: Re: STS D5R
sorry for the double post...
#1585
Wang, can you post some pictures?
#1586
AFM my friend,
The problem to get STS engines in southamerica its PRICING ... i contacted with at least 2 of the southamerica distributors and the price its about US$ 80 more than buying from outside-southamerica dealers ... and paying full taxes and transportation the mark stays on the US$ 20 difference, and on the southamerican price i have to add transportation and my-country taxes for import ...
Thats not good ... ...
#1587
Originally posted by Tabushi
AFM my friend,
AFM my friend,
Send me a PM explaining me more who you contacted and pricing given to you, or give me a phone number where to call you.
AFM
#1588
Any idea when the new .21 On-Road engine will be available? Anybody using the current .21 off-road engine in a On-road situation? How does it compare to the rest.
Thanks for any input,
Smitty
Smitty
#1589
Just wanted to give an update on my .12 d5r. I finally had some good track time to race tune this engine. I had been having a flame out issue and was a little stumped as to where is was coming from. Eventually i realised it was a rich lsn that was doing it not a lean hsn as I was trying to tune for. After setting the lsn on the sweet spot and retuning and re gearing 1st gear on my kyosho RRR, this engine became a monster. It had every engine on the 50m back straight and at the last 10 meters of accel made the other engines( including new sirios, rossi 3/5 ports, os tz, and ns 5 ports) look almost slow.
My track had been changed since last time out and it now has a very long straight section 35 m to a high speed right, 35 m to a 90 right onto the 50m back straight. The 5 port was at home with these long track changes. It was really nice to hear people watching it run say man that thing is fast as I blew by the 500$ italian powered cars at the end of the straight. Even better to have the guys with those italian mills come over and ask about my engine and watch their faces when I told them what it was and the steal of a deal it goes for. Pretty sweet to be able to get a new engine that costs less that a p/s rebuild and will blow the doors off more expensive mills.
With the lower 1st gear change it screamed on the very long infield too! I have also noticed it doesnt mind getting hot. In my italian engines a slightly hot condition cooks plugs and cause grief, but the sts is at home with the hot temps and keeps the plugs in good condition. I am really happy with this engine.
Thanks for all your help Dino and sts team!
#1590
I too fell for the too rich LSN with my D5 but once I realised to lean the LSN (and richen HSN) no worries - very reliable and powerful engines. I'll only be buying STS engines for some time. *BIG THUMBS UP*
GO STS !
GO STS !
