Help with Nova Bearing
Hello all,
I just changed both bearings on my Nova .12 and my crankshaft cased to turn (very hard to turn) when I tighten the flywheel. It spins perfectly fine when the flywheel is not tightened. Is there something wrong? :confused::confused::confused: |
2 things can happened:
1) the main bearing is inserted in the wrong way, look from the backplate if you can clearly see the balls and not the ring from the cage holding the balls. At one edge of the inner ring of the bearing the rounding is bigger fitting the rouding at the same spot on the crankshaft. 2) one of the bearings not inserted far enough |
Thanks! Turns out my small bearing didn't go all the way in....
:blush: |
