Old 01-27-2009, 02:31 AM   #106
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by bboy View Post
Hello All,
Just want to report that I have joined the XXL3 family. Man, it took me over 20 tanks to break in the engine, but is is very very fast with excellent torque.
Too bad that I had to take out the ceramic bearing and conrod set after the break-in. I wonder why they put the ceramic bearing in since it's kind of a throw away.
Anyway, looking forwrad to seeing my new XXL3 in action in the next race!
you had to change your rear bearing? Should last at LEAST a gallon..
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-27-2009, 04:47 AM   #107
Hello All,
20 tanks! wow, mine only took 8 tanks using runner time. i'm suprised you busted the bearing as well, maybe the fuel has a poor quality oil content.
i've only had a bearing go once, and i think sometimes you get a less than perfect bearing. who knows.
the XXL3's are matched pistona nd liners from what i've been told so they should break in quite easily.
TomB is offline   Reply With Quote
Old 01-27-2009, 08:23 AM   #108
Osiris 75's Avatar
Trader Rating: 17 (100%+)
So, how was the performance with the team orion pipe?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 01-27-2009, 06:41 PM   #109
it was fine. i didn't bother trying the novarossi pipe as i have had only excellent performance with the orion pipe. When my home track gets resurfaced i'll test the orion pipe and the novarossi pipe for both performance and run time.
for now i know it runs cooler and quicker with the orion pipe, not sure about run time but i'm guessing it would probably have more run time as well.
Old 01-30-2009, 06:04 AM   #110
bboy's Avatar
Yes, I changed the bearings to regular steel ones.
I took my time breaking in the engine before I started leaning. Given the current economic condition, I guess this will be my last new motor for a long while ... sigh.
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
bboy is offline   Reply With Quote
Old 01-30-2009, 06:35 PM   #111
Trader Rating: 13 (93%+)
Weird.. ive had over 20litres on my 3ct tuned and still the same original bearings
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is online now   Reply With Quote
Old 01-31-2009, 04:22 AM   #112
bboy's Avatar
20L ! Wow .. that sounds very amazing. How lean do you run?
The longest I have had to change is 4-5 litres..
XRay NT1 + Max XXL3
Old 01-31-2009, 04:24 AM   #113
i tune to max performance always
engine temps are normally between 115-125 degrees
do you wanna sell the bearings u removed from your engine?
Old 01-31-2009, 01:04 PM   #114
Nitro-Racer*'s Avatar
only 4-5 liters i have gone through at least 30 liters.... i am also interested on those bearings
Xray Nt1-Novarossi 3sct-KoPropo-GRP-Altis 2.3-RB Fuels
Xray 808 09-RB Killer 9-Hitec-KoPropo-RB Fuels
Nitro-Racer* is offline   Reply With Quote
Old 01-31-2009, 01:58 PM   #115
when i say positive things you still have something to say even though i said the eagle has more topend the xxl3 is the better all around motor so go make love to your xxl3 but it is not faster just better overall.
HoboShop is offline   Reply With Quote
Old 02-02-2009, 12:11 AM   #116
rx7ttlm's Avatar
hmm, what kind of fuel do you run? did you not burn the engine out of fuel and oil it nightly? cause that just seems strange, only time I had bearings die early was with 1/8th buggy when the front bearing got dirt in it. ... did you change it because of grit or axial, or radial play?
Old 02-02-2009, 05:39 AM   #117
bboy's Avatar
I usually change when the bearing feels not smooth. That's pretty much it. I always clean an oil after each time of use.
I use O'Donnell 20 and 25%, and run about less than 230F.
XRay NT1 + Max XXL3
Old 02-02-2009, 07:59 AM   #118
FF25510's Avatar
i'm also ran O'Donnell 20% at below 240F and the bearing can last at least 15L
what was you used to clean the inside of the engine and the bearing was not smooth before or after you clean it .
FF25510 is offline   Reply With Quote
Old 02-02-2009, 07:46 PM   #119
rx7ttlm's Avatar
hmm, did you maybe get some dirt in it? I ran OD fuel and it was fine.. so I doubt it was cheap fuel... I guess you can understand why most of us are all confused lol
Old 02-03-2009, 09:18 AM   #120
DS Motorsport's Avatar
Probably too lean in the high end. This will cause bearings to wear out in 4-5 Liters. I've had the same in my Eagle, pretty much the same engine. First set of bearings was shot in 4 liters.
With the new set i just set it a tad richer, especially in the long mains.
And i changed from Tornado to RunnerTime. Runnertime is a too expensive fuel but you will save a set of bearings with it.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 04:25 PM
MAX POWER ENGINES Secret_weapon Onroad Nitro Engine Zone 334 08-29-2010 10:54 AM
JP Racing First Line .12 on road Stock and Tuned romuald31 Onroad Nitro Engine Zone 153 04-17-2010 05:35 PM
2nd EDITION PERLIS OPEN 09 August 2009 Aik Rccenter Malaysian R/C Racers 318 08-19-2009 09:01 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-25-2009 12:10 AM
So, with 2008 coming to an end, what changes would you like to see in 2009? quietstorm76 Nitro On-Road 52 01-05-2009 03:53 PM
