Longer intake on .21 offroad engine.
What would be the pro's and con's of having a longer intake between the carb and crankcase on a offroad engine ???
In theory a little more low rpm torque at the cost of a little high rpm.
Research intake harmonics for more detailed info. Superflow has some really good info on intake harmonics. BK |
All about 2-stroke tuning:
http://edj.net/2stroke/jennings/ A venturi in the intake will give more performance, if it will be wider and longer I suspect it will be better. If it is only longer I think the performance as the reaction will slow down. But read the book, it is very interesting stuff. |
| All times are GMT -7. It is currently 12:23 AM. |
