Capricorn CL-12E engine
Old 05-13-2009, 02:31 PM
  #166
Riketsu's Avatar
Trader Rating: 33 (100%+)
Originally Posted by GREGORY! View Post
have you notice guys that the engine prices has go up 50-60e?
or i don't remember very well?
Nothing has been heard of these engines again. Nor the car... Has Capricorn bankrupt from trying to release too many things at the same time? Whats going on with this company.......
Riketsu is offline
Old 05-13-2009, 02:40 PM
  #167
GREGORY!'s Avatar
riketsu does any one race these engines in your track?
GREGORY! is offline
Old 05-13-2009, 06:46 PM
  #168
Riketsu's Avatar
Nope man. I have only seen this engine race once, and that was when Eddie Colon came here to race in December.
Im asking because the engine internal's look very good. But I dont like being a test rabbit.
Seems Murnan stopped distributing the engines here. So hence why I ask, what is going on. I am not trying to bash nor discredit the product.
Riketsu is offline
Old 05-26-2009, 07:11 PM
  #169
Unhappy capricorn q5-te
purchased from from murnan modified 2 weeks ago now checked their website and no capricorn engines listed. Just my luck I'll have to put it in my ocm kaos.confused:
olegeezer is offline
Old 05-27-2009, 07:11 AM
  #170
GREGORY!'s Avatar
Riketsu do you know which is the worst?the boys that some time ago was here and talking about this engines...
now they don't even take the time to write,look guys this happened or that..
things are changing so quickly!
GREGORY! is offline
Old 06-07-2009, 05:46 AM
  #171
gunna do's Avatar
Originally Posted by Novarossi View Post
Uriah, no more RRR Capricorn clutch units? They were there about 1 hour ago
hey guys Aaron from ozspechobbies has a RRR capricorn clutch.
hey mr novarossi i just got 1 of these capricorn 12 engines what run in proceedure did you use the 1 that they supply just curious.
thanks brett
gunna do is offline
Old 06-17-2009, 02:41 AM
  #172
Chiefy 707's Avatar
I bought a CL12E from Murnan when he carried the line. I broke it in using the Murnan bench method as well as replaced the conrod after the 1st gallon.. I've put over 3 gallons through the engine so far and the piston still gets stuck on colder days when i first put it on the started box. Runtime has been very good and power has been extremely excellent.
My only concern is that I wish Capricorn had a US distributor again. Capricorn has some great products. I was using a Capricorn glowplug with great results. Same with tires (caution though, the black carbon Kyosho rims can be very brittle. Just don't hit the wall!)
-Capricorn CL12E .12 engine
-Capricorn #6 glowplug
-Capricorn Sirio 2611 pipe and header
-Capricorn black carbon kyosho tires (either 38 or 40 f/r I dont remember!)
I'm really digging the black/silver/red/cf theme of my +Evo/Capricorn combo.
Chiefy 707 is offline
Old 06-22-2009, 07:11 AM
  #173
Default cap engine
hi capricorn factory,
i bought my capricorn engine. i found out when i bring in much on the idle screw my carb become very unsmooth. is it normal or my idle screw is not straight?
I get this problem out of the box.
Let me know
formosa008 is offline
Old 06-28-2009, 05:49 AM
  #174
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i have just started running in my Capricorn engines, and i get the same thing. i didnt quite understand what you were trying to say, but now first hand i know.
when you raise the idle under rich conditions (run in) the slide actually start to lock up. the idle screw is stopping the slide form working freely. im sure once past the run in, when the engine is leaned off, the idle screw wont be screwed in as much. then it wont really be a problem. but something to be aware of.
Pattojnr is offline
Old 07-05-2009, 01:44 AM
  #175
gunna do's Avatar
Hey Patto have you run that capricorn 21cl 9et yet and what do you think of the 12
gunna do is offline
Old 07-05-2009, 08:01 AM
  #176
Pattojnr's Avatar
na havent run them yet.
the 21 looks very good, the 12, also looks good. in the early stage of run in, both engines easy to fire up, stay running easily. i feel the 21 will take some runnign in. the 12 not as much. if weather permitts, i will try to run next weekend.
Pattojnr is offline
Old 07-12-2009, 06:51 AM
  #177
Pattojnr's Avatar
ran both engines today. have put about 3 lts through them both.
the 12 was impressive. still could be leaned out some. but ill leave that for Sydney. had some issues with the 21, but was a plug fault. new bad plug. so once i tried another plug, it was all good. changed fuel for the final, did a couple of tune stops. still pretty rich, but also impressive. both engines seem to be the goods. ill get soem rods for them, change em , and box em up for the nats.
Pattojnr is offline
Old 07-19-2009, 03:17 AM
  #178
gunna do's Avatar
Ran the 12etx at our interclub round today at Brendale.Man all i have to say is WOW and it wowed alot of people even the nova drivers temp is sitting at round 110deg laptimes are in the 18s.I am running nova 6tgf plugs and found that i got better fuel economy than running the sirio 6 plugs.The real test is going to be the QLD state title in 3 weeks.
gunna do is offline
Old 07-23-2009, 04:38 AM
  #179
jca2000au's Avatar
Trader Rating: 9 (91%+)
Default Suitable Pipe for CL-12ETX
Anybody know what is suitable pipe for CL-12ETX?
jca2000au is offline
Old 07-23-2009, 06:17 AM
  #180
Pattojnr's Avatar
i saved my capricorn pipes for the nats.
i used nova 2601 with med header with good results. yet to try the capricorn pipes i got with my engines. the efra number on my cap pipe is 2648, conical header.
Pattojnr is offline
