Old 07-21-2008, 11:04 PM   #1
lil-bump's Avatar
Trader Rating: 83 (100%+)
Default Real head clearence
I'm looking for a way of checking head clearence of a new engine (before breaking). I normally just heat the engine up and bring the Piston to TDC take a measurement with my Calipers and then subtract the measurement of the burn chamber(button head). But it's extremely hard to get a new engine to TDC. I don't want to damage the engine. Any ides would be greatly appriciated.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 07-22-2008, 12:15 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
Normally I push a piece of solder (1mm thick) though the plughole. Bend the endtip a bit so you can get it between the head and piston. Just turn once the piston through the TDC and take out the solder, the flatened sides on the solder is marking the thickness of the real clearance.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 07-22-2008, 07:06 AM   #3
wingracer's Avatar
Trader Rating: 24 (100%+)
That's what I do. The only problem with that is it doesn't take play in the rod into account but that is a whole different story.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-22-2008, 10:35 AM   #4
Roelof's Avatar
True, but the play on on the crankpin of a new engine is nothing more than 0.02 - 0.04mm, beside that, if you want to take care with this then you also have to take care of the flex in the conrod and crankshaft what on full speed can make a 0.2- 0.3mm difference.....
Old 07-27-2008, 04:37 AM   #5
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
The solder trick does work, but getting the piston to TDC has been tricky, so I took and cut a small piece of solder and laid it on the top of the piston, then rolled the crank all the way over then took the piece of solder out and got my measurment.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Clearence Sale NIdaho Mudder R/C Items: For Sale/Trade 0 07-19-2007 06:39 AM
G4 Clearence The Ideas Man Australia For Sale/Trade 15 07-13-2007 06:29 AM
Getting out of R/C Summer Clearence Sale tboned_2002 R/C Items: For Sale/Trade 3 06-18-2007 05:42 AM
clearence sale!!!!!!!! look! REVO MAN R/C Items: For Sale/Trade 8 07-24-2006 10:05 AM
-EP Clearence sale- Carbon_Ta04 Australia For Sale/Trade 9 07-03-2006 11:31 PM
