Percentage of Nitro
Percentage of Nitro
Looks like this summer is time to get a new .12 engine. I'm looking around. I'm thinking either Novarossi 353, Murnan modified Nova 353, or the JP Eagle. While I was on Novarossi's web site getting data I noticed that Novarossi says this regarding the 353:
Fuel recommendation: This engine has been developed to be used with a fuel with a maximum of 16% nitro content and with an oil percentage not lower than 7%. We therefore suggest not to use it with different percentages compared to the ones specified here above.
The track where I run everyone uses 25 percent and I've always used that. I wonder, if I dropped to 20 or 16 percent would I be at a disadvantage? I thought using more nitro gave you a cooler engine and more punch? Or, could I simply tune my engine and more or less get the same power (and lap times) with a lower nitro content? What would be the advantage of using 16 percent as Novarossi recommends??
Rob
Rob
They are set up for 16 because that is the max legal limit in most of the world. It should run fine on 20. 25 you might want to add a head shim to be safe but I have run them on stock head clearance before without problems. 30 definitely add a shim.
i did not have these engine (353 etc)so i can't comment but i down from 25% to 20% on my MAX C5 and OS Speed II, no big difference compare to others engine at track running 25% and i'm running both with stock shim.
In the States we use 25 and 30 percent all the time. I run the 353 Nova and use 25% with a shim amount of .5. It works great with this setting at sea level.
DJ Apolaro
DJ Apolaro
DJ, when you say .5 do you mean a .5mm shim added to the standard shim that comes with an engine? On my JP FX-12 engine it came with a silver shim under the inner head. Do you add another .5mm shim to it? Or the total shim thickness is 0.5mm for all shims added together?
I believe he means .5 total but since I don't have a 353 I would let him say for himself.
Yes .5mm total.
DJ Apolaro
DJ Apolaro
shim on 353..
was contemplating on whether to add another 0.1mm but did not in the end.. after 1 race, i open up my engine head, notice all ok and not pit marks on the head (no detonation also..).
guess it's ok then not to add shim ? ... what you guys think ? ...
thanks in advance..
adding a .1 shim would give you a bit more top end / rpm with slight decrease in bottom end.
I have been running all my .12 motors between .35 - .45 total clearance.The larger clearance on larger flowing tracks and at altitude.
any ways to tell if u added too many shims? what's the effects?
i'm been using 0.4-0.5mm of shims for my engines with 25% nitro; sea level.
