Old 06-30-2008, 06:22 PM   #1
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
Default Bearing removal and install?Any tricks?
Was wondering what temperature you get your motor to remove and install the bearings?I had to heat my motor up to 375 degrees in the oven to get the bearings to come out.I started the temp at 200 and after gradually working my way up to 300 I sprayed some wd on it to lube it up some since the bearings wern't coming out then gradually went up to 375 where they finnaly came out.I am working on a grp/ninja 21.
sm1nts2escape is offline   Reply With Quote
Old 07-01-2008, 06:39 AM   #2
I use a RB bearing puller and a Novarossi bearing installer, don't need to heat up engine and works good evrytime.
ich weiß
hello is offline   Reply With Quote
Old 07-01-2008, 06:52 AM   #3
M7H
M7H's Avatar
Be glad your bearings didn't come loose at 200 degrees, because this is not even the working temp for an engine!....
I let my oven heat up to 400+ (225 Celcius) before even trying to get the bearings out....
Any tool used to put bearings in with a cold crankcase, will be done with atleast some force... this I don't like....
Serpent
M7H is offline   Reply With Quote
Old 07-23-2008, 08:50 PM   #4
CKmaxx's Avatar
Like what was said above...I heat my engines to at least 425 degrees and usually the rear bearing falls right out and the front one needs at little tap with punch and hammer.
And also, I don't agree with extracting and installing bearings in a cold crankcase. It could result in a loose bearing fitment. Then you're hooped....
CKmaxx is offline   Reply With Quote
Old 07-27-2008, 04:32 AM   #5
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I agree that with the engine case being cold, putting the bearing in causes an impropper fit. I use the OFNA bearing puller when removing the bearing when the engine is around 350-375deg.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 07-30-2008, 09:21 PM   #6
DogboneS's Avatar
Trader Rating: 20 (100%+)
I had the best luck with my Milwaukee heat gun(on High,500+ deg) with my Ninja. Front bearing seal failed, and the swap out took 5 minutes to heat, get the bearing out, and install the new bearing while the case was still hot. Hang the block off a coat hanger, and use caution. A 1/2 inch wooden dowel is handy to have close when doing the swap, won't scratch internals, usually fits to remove front bearing. Assemble with the crank as the alignment tool.
DogboneS is offline   Reply With Quote
P21-5 Rear Bearing Removal ehartman_49348 Nitro Off-Road 1 01-21-2008 04:15 PM
Tool to install Ball Bearing ScanneR Nitro On-Road 3 03-27-2006 07:28 AM
bearing removal beer_ninja Rookie Zone 10 10-21-2005 10:05 AM
Proper clutch shoe removal and install? Ducati-Rider Onroad Nitro Engine Zone 6 04-15-2004 12:29 AM
Crankcase bearing removal? aussiedanny Australian Racing 15 04-01-2004 05:14 AM
