NovaRossi M12 Parts Info Please
TRoday during testing with my MTX3 my engine blew up, I was having a very hard time getting it to run cool as every setting I had it at after a few laps it was running very hot. I had turned the main mixture 5 turns from bottom and still managed to hit 360deg ? in any case it really doesnt matter now as the con rod bushing failed and all the parts made there way threw the engine and mangled the piston.
I am hoping I can just replace the set and all will be good but I do understand this is an old engine (came with my first Serpent Impulse) but I am hoping there are parts somewhere for this engine so I can bring her back to life as I really can't afford a new engine at this time.
Thanks for you help R/C Tech
Sean
Sean
Sean
Sean
http://www.murnanmodified.com/
Just wondering if anyone knows or can remember what the output of the M12 was? I am almost certain this is the Mugen M12 that was offered in the kits many moons ago produced by NovaRossi. I have owned this engine for over 9 years and had gottin this engine with the purchase of a used Serpent Impulse( they came with the SX12 not M12) I am not totally sure but 1.2 HP comes to mind when I try to think back. Does this sound about right? If so I am currently looking to replace it with a NEW NovaRossi NS12TS1 which is rated at 1.48 HP and is a Turbo plug engine. I know this engine is not the same as the new LL3 but I am thinking it is still better then my M12 when it was new over 10 years ago.
Thanks for the info R/C Tech
Sean
Sean
