Old 04-06-2008, 12:20 PM   #1
Trader Rating: 44 (100%+)
Default HPI 21R SC...replacement parts?
i know this is an old motor made for the hpi proceed but it's made by nova and it's 9 ports i was wondering does anybody think the 35+21 or 359 P/S/R will fit?
i could take pictures of the case for you guys and go from there...any input would help...i really wanna put this beast together and run the snot outta it
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 04-06-2008, 08:00 PM   #2
pics:
crankcase
crank
sleeve pics
lmk what you guys think..sorry for crappy quality but let me know if you need more info
T5M 7.5
22 3.0 7.5
Old 04-08-2008, 01:31 AM   #3
so no one here can help me? come on i know there are some engine guru's here....please help
btw...the case and things look very similar to other novas so i assume should work...also the storke/bore,bearing sizes are the same...so I am thinking of getting a jp p/s/r set + ceramics for this
gonna be running in buggy/truggy what would you suggest?
T5M 7.5
22 3.0 7.5
Old 04-08-2008, 07:43 AM   #4
Rob D's Avatar
I have two of them. I will look into it for you. THis was and still is a good motor.
Rob D
RC America-X Ray- Team Scream -Pro Line-TQ Wire -LRP-Boom Rc Grapichs & Design - RJD Racing-
Devil Spit Traction Compound
Rob D is offline   Reply With Quote
Old 04-08-2008, 08:30 AM   #5
Roelof's Avatar
Send a message via ICQ to Roelof
It is a 7-port engine and I believe based on the models like the Serpent EVO3 engine because it has 1 exhaust poort and no MES (= with 2 extra small upper side exhaust ports).
I advise you to take a look into the new 7-ports Novarossi Basic engine which is basicly the same set. I fitted a Basic 3-port set into an EVO5 and it runs very good.
I am just interested why HPI even did get this engine, such expensive engines is not in the line of HPI or was it only for the Proceed ?
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 04-08-2008, 01:10 PM   #6
yes it was for the hpi proceed it was during the time period in which HPI was getting nova based engines
they had this one
and i believe the pull start and non pull start .12's around the time of the HPI RS4 NITRO 2 kit
and the only reason for calling it a 9 port is because that's what the info on the website says
thanks for the reply i'll look into it
T5M 7.5
22 3.0 7.5
Old 04-08-2008, 10:18 PM   #7
DogboneS's Avatar
Trader Rating: 20 (100%+)
Don't know if this will help, HPI numbers don't give a hint of the Novarossi p/n# yet the bearing size may help narrow it down...
http://www.hpiracing.com/graphics/instr/i-1801.gif
14mm crank and 14x25x6mm main bearing. Plus inst. pic says nova 3.5 on the side of the block.
DogboneS is offline   Reply With Quote
Old 05-30-2008, 04:52 PM   #8
found that it in fact is like any other nova case has a p5 set installed just gonna replace bearings and i've fired it up seems to run well...or so i hope can't really tell until i change bearings and slap her on for a full run ya know
T5M 7.5
22 3.0 7.5
Old 05-31-2008, 05:24 PM   #9
wingracer's Avatar
Trader Rating: 24 (100%+)
Glad to see you got it running. It was a very good motor and would still make a decent practice or club race motor. In the early days of TC racing I had an HPI nova .12 side exhaust that I still say is the best .12 I ever had.
As for pistons and sleeves, I believe any of the Nova motors from that time would be interchangeable. An R1 or RB C4 sleeve may work but not positive.
wingracer is offline   Reply With Quote
Old 06-02-2008, 03:36 AM   #10
my buddy has one hooked up 2 a jp-1 in his truggy and that thing is ballistic...easily speeds past vspecs and other nova's
T5M 7.5
22 3.0 7.5
Old 12-04-2010, 04:02 PM   #11
Just found this thread so I hope you guys don't mind if I bring it back to life. I used to work in the industry. I'm out of the hobby now but I have two 21R SC's brand new still shrink wrapped from the factory. I'm never going to use them as there isn't an on road scale around me for about 200 miles! I'll let them both go for $500 if anybody wants them want them. Heck I have an HPI Proceed unbuilt and still in bags along with unpainted Toyota and Lola bodies for it. Let me know.
Chad
Dizzle is offline   Reply With Quote
where to buy SH .28 engine replacement parts? skyblueblue Singapore R/C Racers 17 05-22-2008 09:52 AM
Where to get replacement Kyosho parts? Phizinza Australian Racing 2 07-29-2006 07:31 PM
Where to buy Sirio replacement parts?? Colt4g63 Onroad Nitro Engine Zone 6 06-25-2006 02:19 AM
suggested replacement parts (rs4 3) alecks Nitro On-Road 3 05-07-2006 09:51 PM
