Old 03-28-2008, 01:27 AM   #1
NitroWD's Avatar
Default Temp ok, plug wire distorted.
hi all engine gurus,
just wana check what could cause the plug wire to become distorted (and white) if the temps are ok (and smoke is visible)? about 120degC...
piston head checked and it's ok (shiny, not black and not 'sandblasted')...
still too lean?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 03-28-2008, 02:29 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
To high compression ?
to low plugnumber ?
to high nitro content ?
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 03-28-2008, 06:31 AM   #3
Send a message via AIM to slawhammer Send a message via MSN to slawhammer Send a message via Yahoo to slawhammer
Default Distorted Glow Plug
Well my friend...have you ran out of fuel?If you run out a couple times it is not good for engine.. And also very lean engine will cause
your glow plug to turn white or burn off.I have read glow plugs for years..Best way to tell how engine is running...I think if you check
www.amainhobbies.com in tools you might find a glow plug loupe and a card how to read a glow plug..think like 9 bucks plus shipping... Oh yes temps are just for ref point..go by good blue smoke...You might want to rich high side a little....All else
fails go back to factory settings and start over...Hope this helps...
Last edited by slawhammer; 03-28-2008 at 06:35 AM. Reason: might want to richen up high side or go back too factory settings
slawhammer is offline   Reply With Quote
Old 03-28-2008, 06:54 AM   #4
NitroWD's Avatar
roelof: engine was shimmed (shims of 0.5mm) for 25% nitro which i'm using with hot plug 6.
slawhammer: yup, i've run out of fuel...
btw, if you are done for the day, do you run whatever nitro that's left? i suppose we dont leave nitro in the carb right?
Old 03-28-2008, 08:32 AM   #5
Default Glow plugs
Ok yes I have ran out of fuel my self..but try not too..Ok end of your day and if you have fuel left in tank ..suck it out with fuel bottle.and run engine too get carb fuel out ..then open throt and put in about 6 drops of afterrun oil ..roll engine over to get after oil inside of engine..Do not use your igniter.
now you have the engine lubed up for next time you go to use it..
But you might like I mentioned go back to factory settings on your needles and start over and use a new glow plug...don't go mush by temp...go by good blue smoke ..run your car or truck for a couple minutes making passes and driving it..then start with high side needle lean at in 1/8 turn ..drive it bring in and adjust again 1/8 in lean keep doing this..but watch your smoke..
then go to your low side needle do the same..when done adjusting might have to your idle a little..go by what your manual says for carb opening maybe 1 mm .done with idle screw....just go by good blue smoke..don't worry too much about temp...You can spit or put a drop of water on cooling head..if you count to like 8 too 10 your ok on temp....Hope this will help you out.. I Use OS #8 plug but check your mfg for your engine..
Old 03-28-2008, 08:38 AM   #6
NitroWD's Avatar
so...residue nitro in the carb just let it idle away?
the drop of water on the heatsink shld boil off after 8-10secs?
based on current settings for 25% nitro; if i use lower nitro or add another 0.1mm shim; normally i'll have to lean the engine more?
Old 03-28-2008, 10:02 AM   #7
matts6887's Avatar
Send a message via AIM to matts6887 Send a message via MSN to matts6887
I hate to disagree here, but I do on at least one thing; temps are not just for reference, they are what quite a good number of peep go by to tune a engine. Especially important because usually(not always but usually) anything above 300*F is a danger zone for a nitro engine. Also the fact that just by reading a plug is not always the best way to tell how a engine is running; blue smoke trail and temps also play a key factor here usually....
"If it ain't broken.....you arent driving it hard enough"
matts6887 is offline   Reply With Quote
Old 03-28-2008, 03:07 PM   #8
Sp Racer's Avatar
An early clutch , dragging drive train or brakes or early 2 speed will affect temps - the combination of smoke vs plug condition is the best IMHO -
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 04-03-2008, 10:22 AM   #9
Default Temps
Well all in all said..you are some what right..But there a lot of temp device's that are off by the numbers ,not accurate..I have seen the off by 20 to 30
dergees...If you use one then use the same one..and like I said for ref..You can use the old water or spit test on the cooling head..1 drop of water or spit
on head count to 7 your ok...any MORE number your in trouble..Too HOT.. Is still your best bet Is good blue smoke and learn how too read a glow plug..
Last edited by slawhammer; 04-03-2008 at 12:07 PM. Reason: correction..any more Number than (7)
2 Cell LiPo, 4 Wire Balance Plug? monkeyracing Radio and Electronics 8 01-14-2015 02:18 PM
Turbo plug Vs Standard plug mrhenning11 Electric Off-Road 1 04-16-2007 09:20 AM
Cooler plug - lower running temp? New_Toasted Onroad Nitro Engine Zone 7 08-13-2004 02:11 PM
Turbo plug vs standard plug shortygy Onroad Nitro Engine Zone 5 08-13-2004 04:10 AM
Anyone know where to buy "26 Awg, 22 Stranded Wire" or typical antenna wire? Thanks Shrub Electric On-Road 9 04-16-2004 05:57 PM
