Old 09-23-2008, 11:25 AM   #31
MHarrison's Avatar
Originally Posted by JayL View Post
The eagles you've seen run must have the wrong pipe...I make 6:30 with the 2602 and my eagle
The black first line engines are very similar to my eagle on my local track, maybe on a huge track the differences would be more obvious
6:30 wow , I need you to tune my motors . But seriously , Yea, I think they were running the 2630 pipe, a real fuel eater.
And I do agree, the First line Engines are very good motors. I have yet to take it to our Large track to compare.
MHarrison is offline   Reply With Quote
Old 09-23-2008, 11:27 AM   #32
MHarrison's Avatar
Originally Posted by Team Kamikaze View Post
The JP 12P3L First line Black engine are actually the FX T03 MT without a ceramic bearing, but performance wise, it is the same, they are as fast.
Yes, they even have the FX stamped on the side of the block.
Old 09-23-2008, 12:38 PM   #33
Roelof's Avatar
Send a message via ICQ to Roelof
That says nothing about the inside. These engines are based on the Novarossi Basic engines and I can say that there is no "microcasted" piston used....
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 09-23-2008, 01:29 PM   #34
Team Kamikaze's Avatar
Yes, it uses a CNC machined bar aluminum piston, which in my opinion is better.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 09-23-2008, 03:08 PM   #35
MHarrison's Avatar
I was simply agreeing it uses a FX block .
Are you Sure it's Not Microcast ?
Old 09-23-2008, 04:16 PM   #36
Roelof's Avatar
Yes, it is not microcast and the piston is also made from a weaker material. With one modified 3.5cc basic engine I already had an exploded piston as also a clubmember had one.
I can not tell how the 2.1cc are but I presume they use the same materials but the weight is less so the forces by movement are also lower compared with th 3.5cc engines.
Old 09-24-2008, 10:19 AM   #37
MHarrison's Avatar
Well I know its not a normal CNC piston, It breaks in just like a Microcast piston, Starts out with decent pinch and by the time you get 10-12 tanks heat and cooled threw it , It's just compression with a very small amount of pinch. Just like a Microcast does. as far as exploding pistons , wow,Hope to never see it happen.
Old 10-16-2008, 05:40 AM   #38
mrx
mrx's Avatar
Trader Rating: 19 (100%+)
So has anybody ran this engine with the ninja pipe? I currently own a ninja and was think to get this engine on next so would like to know if is ok with ninja pipe what other matching pipe for this little beast.
mrx is offline   Reply With Quote
Old 10-16-2008, 08:16 AM   #39
The best pipe for this engine is the JP 2620, the Max 2602 also works good.
Old 10-16-2008, 08:19 AM   #40
MHarrison's Avatar
By Far the Best pipe for this motor is the Max 2602. I ran it at the Sedan Nats Last week. So many People were telling me the raw power it showed on the back straight. And I felt it had great bottom & mid range as well.
Old 10-16-2008, 07:47 PM   #41
mrx
mrx's Avatar
That is great to know that jp 2620 pipe is good for this engine and i happen to have one laying around
Old 10-20-2008, 07:47 PM   #42
You will be surprised how it wakes up the engine, by far the best pipe for the JP P3L.
Old 10-28-2008, 10:32 PM   #43
For racers who does not want to spend a lot of money on a race engine, the JP 12 P3L stock version is now available.
Old 10-29-2008, 08:16 AM   #44
Francis M.'s Avatar
Wow that is a great deal.....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 10-30-2008, 11:26 AM   #45
The JP 2620 pipe set are now available for your Firstline, FX and Eagle .12 engines.
JP Racing First Line .21 on road Stock and Tuned romuald31 Onroad Nitro Engine Zone 6 04-12-2008 07:13 PM
help keeping fuel line in tuned pipe. NitroMaxx3.3 Nitro On-Road 12 01-03-2007 05:20 AM
Sport tuned vs stock surrealmaterial Electric On-Road 8 08-15-2006 02:30 AM
