Pinch too TIGHT!
Old 01-19-2008, 05:25 AM
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Default Pinch too TIGHT!
I have a piston and sleeve that is so tight that even after running in 3/4 a gallon, is so tight that I have to take the engine apart to get it unstuck. Any Ideas? Idle temps for running in has been from 170 to 205.....
The piston keeps getting stuck and when I remove it, it has a sticky film on the sides of the piston, and to get it to start up again, I have to clean the film off the sides of the piston....I've done this 3 times and I'm about to toss it to the side.
thanks
rcfoolz is offline
Old 01-19-2008, 07:18 AM
Roelof's Avatar
Pre-heat the engine with a hairdryer for less pinch....
About the film... what fuel are you using? Maybe worth a try to use another brand fuel?
Roelof is offline
Old 01-19-2008, 07:37 AM
rcfoolz's Avatar
when I use a heat gun, the engine is still to tight to get unstuck after I shut it down. I've tried Sidewinder, RocketScience, and Werks fuel, it doesn't make a difference, it just gets this sticky film on it.
I was thinking about taking the sleeve out and heating it with the heat gun and pushing the piston to the top and letting it cool. after that I would have to heat it again to get it out, but I though maybe it would resize it just a bit....any thoughts on that?
rcfoolz is offline
Old 01-19-2008, 08:05 AM
dude man, pritty obvious, if it's this tight, put more headshims man
TomB is offline
Old 01-19-2008, 09:36 AM
cdelong's Avatar
run it up to 220- 225F. Does not sound like your fuel is good with that film.
cdelong is offline
Old 01-19-2008, 03:15 PM
CKmaxx's Avatar
Your kidding, right?
CKmaxx is offline
Old 01-19-2008, 05:05 PM
cdelong's Avatar
it lowers the compression and does not abuse the rod as much. I always add a tenth or two for break in.
cdelong is offline
Old 01-20-2008, 02:09 AM
no i'm not. if this does not fix it, then it's possible that the piston and sleeve is a very bad match, and something went terribly wrong when it was assembled in the factory. might be one of those 1 in 5000 type scenarios.
TomB is offline
Old 01-20-2008, 02:26 AM
joe_jenkins's Avatar
such as my murnand modified 35 plus 31 that god broke in half at the block
joe_jenkins is offline
Old 01-20-2008, 02:27 AM
i was getting off our second straight and then doin a 180 then going into the S curves when a guy in front of me hit a pipe and went under the pipe and i hit him and his bumper hit the head of my car and ripped it backwards
Old 01-20-2008, 02:07 PM
rcfoolz's Avatar
I've had the discusion with a fellow racer that siad the same thing about the fuel....I'm going to be running another brand fuel through it after the Chargers/Paitriots game......I'll run 3 tanks in it to test the theory and tear it down and check the pinch/film build up.
rcfoolz is offline
Old 01-20-2008, 03:52 PM
MHarrison's Avatar
MHarrison is offline
Old 01-20-2008, 05:06 PM
rcfoolz's Avatar
still very tight, but no film build up this time......
rcfoolz is offline
Old 01-20-2008, 05:14 PM
JFCJ's Avatar
Trader Rating: 31 (100%+)
rcfoolz,
what are you using for afterrun oil?
J
JFCJ is offline
Old 01-20-2008, 05:19 PM
rcfoolz's Avatar
I hadn't used any in that engine with the brand new piston and sleeve......It has 7 tanks in it, I was using sidewinder for the first 4 tanks, and then I ran 3 tanks of RocketScience. I couldn't realy tell you true temps due to the ambiant air is cooler then it was with the other fuel.
rcfoolz is offline
