Old 04-02-2008, 06:21 AM   #91
O11
Just got my JL EVO3 Tuned and I intend to run it on a 16% fuel. Since this engine is shimmed with 0.3mm for 30% fuel, what would the correct shim for 16%?
O11 is offline   Reply With Quote
Old 04-02-2008, 01:45 PM   #92
Team Kamikaze's Avatar
It should be shimmed at a total of .20mm. (take off the .1mm shim)
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-02-2008, 01:48 PM   #93
I have a friend in Asia who wants one, but don't know where to buy it, where in Asia did you buy your JL Tuned engine?
hello is offline   Reply With Quote
Old 04-02-2008, 08:54 PM   #94
Send a message via AIM to barry Send a message via Skype™ to barry
u can buy from www.kamikazercracing.com,im from Singapore,me and my friend ordered before from them last month,very good service and shipment arrived 3 to 4 days which is earlier than the expected date.Thank u team Kamikaze..
barry is offline   Reply With Quote
Old 04-03-2008, 07:09 AM   #95
Maximo's Avatar
Originally Posted by German Muscle View Post
I noticed a sleeve shim in the pics. Dont wanna loose that. Looks like they prolly just shimmed the stock JL3 liner up and prolly gave it some rotor timing.
Motor looks hot though. Anyone ran it?
thats a lame way to raise timing LOL !!!!! its almost like cheating !!!
Maximo is offline   Reply With Quote
Old 04-09-2008, 09:24 AM   #96
RayJ's Avatar
For those not in the know. Shimming the liner effectively increases exhaust timing, and port timing. What you will gain is more rpm in the motor and a shift in the torque curve to higher rpms. It will also help smooth out the bottom end abit. I'm not sure on the evo3 tuned version if they changed the crank timing. It's pretty aggressive already. Shimming is alot cheaper than actually re machining the liner.....or carving up the piston. Those that do add shims to a liner MUST reshim the head. Raising the liner will reduce compression of the motor if all the standard shim are left in place.
RayJ is offline   Reply With Quote
Old 04-09-2008, 10:36 AM   #97
It's actually a smart way to do it, as you can adjust your timing anytime you want to! we can call it a "variable/adjustable exhaust timing".
The JL "Tuned" are already shimmed for 30% out of the box.
Old 04-11-2008, 11:58 AM   #98
JL RACING is offline   Reply With Quote
Old 04-14-2008, 09:52 AM   #99
Jeff Huang's Avatar
Originally Posted by JL RACING View Post
Hey jeffery, what time are u gonna pick me up to hit the club where we're talking about??
Jeff
JL Racing 2007' NT1
Team Titan
X-Pro Racing
Jeff Huang is offline   Reply With Quote
Old 04-14-2008, 10:00 AM   #100
You might as well just call Jeffrey.
Old 04-14-2008, 10:50 AM   #101
Roelof's Avatar
Send a message via ICQ to Roelof
That is no shim, they only did cut away a small edge so the rounding inside the crankcase will not be in the way for a correct fitting of the sleeve.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 04-24-2008, 06:28 AM   #102
Am i reading this correctly? to break this engine in,all i need to do is run one tank at idle then start tuning to race?
cdub is offline   Reply With Quote
Old 04-24-2008, 07:19 AM   #103
Yes!
Old 04-24-2008, 09:06 AM   #104
THANK YOU-you shipped mine to VA yesterday!
Old 04-24-2008, 09:51 AM   #105
Maximo's Avatar
Raising the liner does increase timing...but it raises the boost and transfer timing much more then it lists the exhuast timing... lifting the liner may raise the boost timing lets say 10 degrees but its only going to add 2 degrees to exhaust, which is going to affect blowdown timing ..... I guess its a cheap and easy way to add a little punch to a motor, but its not the same as actually cutting the ports manually
Sirio "Kanai EVO III" STI Tuned Off-Road Competition Buggy Engine slow supra R/C Items: For Sale/Trade 3 08-26-2008 12:25 PM
Brand New NovaRossi 321P "TUNED" and modified by Jim Hottinger, extra new P/S! Speed_Racer R/C Items: For Sale/Trade 2 12-30-2006 09:37 AM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
What effect does "Chambers" have on the performance of a Tuned Pipe? racer rich Nitro On-Road 2 08-10-2002 01:50 AM
