Old 03-05-2008, 10:42 PM   #61
you have more? I see website say out of stock I want order 2
I see in my race track engine very fast. when back in stock?
E.Rocha is offline   Reply With Quote
Old 03-06-2008, 05:53 PM   #62
Team Kamikaze's Avatar
E.Rocha both engines are shipped this afternoon, it says 7 days to your country, thanks!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-06-2008, 07:06 PM   #63
gracie
Old 03-08-2008, 12:57 AM   #64
I recommended that pipe for JL tuned ?????
Can be used with 16% nitro, a problem ?????
cmpx is offline   Reply With Quote
Old 03-08-2008, 10:05 AM   #65
Sorry, I did not understand the first question, please clarify.
and for question #2 = The engine is shimmed to run on 30% which makes 6 minutes on a 75cc Fuel Tank. yes plenty of run time.
Old 03-11-2008, 08:04 AM   #66
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Got the order thanks Sam. great service for sure. 3 days from USA to AU. 5 days from Victoria to Perth.
thanks again. Paul...
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-12-2008, 11:43 AM   #67
Now time to try the new JL "TUNED" and let us know how it goes.
Old 03-14-2008, 07:01 AM   #68
aussies1129's Avatar
Trader Rating: 74 (100%+)
HI Kamikaze-Sam,
do you have a preference on run in method for the tuned and evo3 engines?
pm me if you like
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 03-14-2008, 02:03 PM   #69
Originally Posted by aussies1129 View Post
HI Kamikaze-Sam,
pm me if you like
cheers
First tank = Idle (just to break in the con-rod)
Second tank = According to JL himself he said just lean it out! run it at the track, just make sure you have plenty of smoke coming out of the pipe.
Third tank = race tune it, it will be good to go.
Old 03-16-2008, 01:59 AM   #70
Hi Sam
whats the best way to remove the sleeve on my picco evo2?
cheers
H.E.I AUSTRALIA
Old 03-16-2008, 06:46 AM   #71
Hi Sam
cheers
I used a heat gun with the head and back plate removed. Once hot enough, I then used a spare (long) body post to push the sleeve through from the back plate while the piston mid way between BDC and TDC. This will avoid any scratches to the sleeve if your hand slips.
Mugen Seiki USA
Dennison J is offline   Reply With Quote
Old 03-16-2008, 08:09 AM   #72
I forgot about a heat gun but that worked very easy, I just heated it up and poped it out with a plastic tool.whats the best stuff to cleaned your motor out with ?dentured alcohol?
thanks for your help!
H.E.I AUSTRALIA
Old 03-16-2008, 10:47 AM   #73
I would not recommend alcohol as I think this could damage the silicone in the crank. (Too much of it) Actually, the engine should be cleaned before you take it apart by covering the intake and exhaust ports. Simple green works great and warm water.
For the internals you could use the fuel itself and a small brush. Remember to lube the bearings, cod ron and other contact surfaces before you assemble it to avoid premature wear when starting it back up.
Mugen Seiki USA
Old 03-20-2008, 12:46 PM   #74
Dennison,
Let me know when you want yours shipped to you.
Old 03-20-2008, 01:10 PM   #75
Dennison,
Shhhhh. Don't let the competition know.
Will let you know soon.
Mugen Seiki USA
Sirio "Kanai EVO III" STI Tuned Off-Road Competition Buggy Engine slow supra R/C Items: For Sale/Trade 3 08-26-2008 12:25 PM
Brand New NovaRossi 321P "TUNED" and modified by Jim Hottinger, extra new P/S! Speed_Racer R/C Items: For Sale/Trade 2 12-30-2006 09:37 AM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
What effect does "Chambers" have on the performance of a Tuned Pipe? racer rich Nitro On-Road 2 08-10-2002 01:50 AM
