Old 08-17-2008, 08:47 AM   #256
Team Kamikaze's Avatar
Originally Posted by stefan View Post
Now that's even better than your statement in WC thread.
You REALLY thought hard how you could make any connection between your beloved JLR and the engine Daniele ran, huh.
Very creative, but unfortunately complete BS.
As I said in the other thread, Daniele is running Picco heatsinks in all his cars due to the sonsorship deal with Picco.
fact is that he is building his own engines for himself and trust me, they have not much in common with the JLR.
Running Picco heat sinks? why hide your own engine line, if it is good ,
just to let everybody know that IDM modifies his own engine and
JL "TUNED" is a re badge PICCO EDO modified engine. and there is a difference, that is
why the PICCO EDO was used at the world championship....... and it won!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-17-2008, 12:19 PM   #257
stefan's Avatar
Send a message via AIM to stefan
You are just discrediting yourself and that dumping price engine you seem to love so much.
stefan is offline   Reply With Quote
Old 08-18-2008, 03:57 PM   #258
Originally Posted by RedRC View Post
Hey Guys, Just to clarify that Daniele was using 'Picco' engines, not IDM. Daniele corrected us earlier in the week when we wrote IDM engines, he was never claiming to be running IDM, and then just using a Picco branded motor. This is a win for the Picco motor, and it was Picco that paid for his trip to the Worlds so he wanted us to emphasize this.
Posted by RedRc in the 2008 IFMAR 1/10 200mm On Road World Championships thread.
Old 08-19-2008, 05:12 AM   #259
Mugenville's Avatar
Trader Rating: 25 (100%+)
Is Stefan the new Walley Edmonds seems to now alot about everything
Proud team member of "Team Mugenites" 2008 PDNR 2.4 Hr Victor's
Just finishing a race is a victory in itself
Jeremy Clarkson
"When you push a car past 180mph, the world starts to get awfully fuzzy. When you go past 200mph it actually blurs. The Bugatti Veyron is mind-blowingly, stunningly brilliant. It deserves 12 stars. Simply as good and as fast as it gets"
Mugenville is offline   Reply With Quote
Old 08-19-2008, 07:16 AM   #260
wingracer's Avatar
Trader Rating: 24 (100%+)
Isn't he the one with "Red dot's suck" in his sig? That statement alone should discredit everything he says.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-19-2008, 09:48 AM   #261
Rob you nailed it
Old 08-20-2008, 01:58 AM   #262
NitroWD's Avatar
i think it's time to let it go and give each other a break?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 08-24-2008, 01:06 AM   #263
aussies1129's Avatar
Trader Rating: 74 (100%+)
hey guys whats the best way to get the internal bearing out of the tune?
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 08-25-2008, 04:34 AM   #264
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
cheers
Heat it up to 450* (i think F) in a conventional oven... Using a mit glove (for the heat), just tap it out... To get it back in there... Place the engine again in the oven at the same temperature... And place the bearing inside the freezer for atleast 10 minutes... If you want it easier, place it in a glass filled with water and ice and it will cool faster. But after installing it, you gotta clean that water with WD-40. To install it... I used an old toothbrush that I have in my pitbox to clean stuff, and I placed the rear bearing on the other side of the toothbrush to have complete control of it... If you removed both bearings, I'd suggest to get the inner first, then the outer.... Remember to remove the carb and any other component and just stay with the crankcase alone...
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-25-2008, 04:56 AM   #265
hey thanks for that all good with the inner bearing except the outer bearing came apart leaving the ring still in the engine so i am trying to work out how the hell to get the ring out without scratching the crap out of the engine looks like I may have to take it to a bearing shop to get some advise as i am all out of options??anyone?
cheers for the help!
H.E.I AUSTRALIA
Old 08-25-2008, 06:36 AM   #266
Riketsu's Avatar
Wow... That sucks big time... Only way I see it, is to heat it even more... Get it up to 500 then with a flathead screwdriver try to get it by pushing it through the crankcase (inserting the screw driver through where the backplate should be). Dunno if the crankcase can withstand 500F.... Probably can... But if your not in a hurry, go see if you can get a professional to do it...
Old 08-25-2008, 06:57 AM   #267
yep thats for sure I think thats the way to go also I notice a small shim that came out not the ones under the button I looked at the diagrahm but dont see anything is there a small copper shim atop of where the sleeve goes in cause it just came out and I dont remember seeing anything there before??
cheers
H.E.I AUSTRALIA
Old 08-25-2008, 07:08 AM   #268
wingracer's Avatar
Yep, the tuned has a sleeve shim that goes between the sleeve and the crankcase.
Team Shepherd USA
Old 08-25-2008, 02:20 PM   #269
thanks I thought so does anyone know where I can get one as this shim is in need of replacing?
cheers
H.E.I AUSTRALIA
Old 08-25-2008, 02:22 PM   #270
cheers
From past reading, you cannot get just that shim.
Baedarlboo is offline   Reply With Quote
Sirio "Kanai EVO III" STI Tuned Off-Road Competition Buggy Engine slow supra R/C Items: For Sale/Trade 3 08-26-2008 12:25 PM
Brand New NovaRossi 321P "TUNED" and modified by Jim Hottinger, extra new P/S! Speed_Racer R/C Items: For Sale/Trade 2 12-30-2006 09:37 AM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
What effect does "Chambers" have on the performance of a Tuned Pipe? racer rich Nitro On-Road 2 08-10-2002 01:50 AM
