Old 01-06-2008, 09:45 AM   #16
JetMD's Avatar
There was an issue of Extreme Rc where they did dyno tests of the different groove cuts. I don't remember what engine they used to test it and it may differ between engines. Anyway, the highest results they got were when they cut three grooves that were very close together and would line up directly above the center/large intake port on the sleeve. That's what I did with my TZ and like I said, felt a lot more bottom end grunt.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 01-06-2008, 07:13 PM   #17
you are refering to the port behind the exhaust port right JetMD?
TomB is offline   Reply With Quote
Old 01-06-2008, 08:48 PM   #18
MHarrison's Avatar
Wow JSPEED, You got ALOt To LQQK for now.Better get to writen them new rules.
MHarrison is offline   Reply With Quote
Old 01-07-2008, 04:55 PM   #19
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
play nice. what if we find a car you tune i'll drive it but then there will be a rule that you cant tune for this class
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-07-2008, 06:22 PM   #20
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Until IFMAR recognizes it, and his sponsor distributes it I don't think he cares...of course this is an assumption and you know what they say about assuming. Then there will be a revision to the rule because I assumed something and he pitted under my tent and we were running 17.08546789524% nitroethane instead of methane and.......................
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 01-07-2008, 07:47 PM   #21
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
When you are all edjucated on this, just put a few drops of Peroxide in the fuel to start changing things up too
Or if you realy want to get past all the timing and play with a stock engine, you can pinch it around the ports, shave the bottom edge of the piston, rework the case along the intake ports, open up the exhaust hole in the case......swap out the piston with one thats the same size, but is light-weight....Hmmmm the list goes on and on!
But you know, I run only stock motors any more......I hadn't done work to anything in over a year!........Break them in right and with a good tune, you have what you need to win.
rcfoolz is offline   Reply With Quote
Old 01-07-2008, 09:58 PM   #22
Foolz, what does a larger exhaust port hole do exactly? (hole on the case, not the sleeve) i was thinking of enlarging the hole on my kyosho crf. Would i get more torque or more top end?
cheers
Old 01-08-2008, 04:44 AM   #23
MHarrison's Avatar
I tuned Someones car , But he thinks I tuned him out of the park. I can't tune for anyone anymore.
Now if you show your butt up to the track, we could work something out.
Yes FOOLZ, What does a larger Case bore do. Inquiring minds wanna know.
Old 01-08-2008, 05:02 AM   #24
joe of loath's Avatar
interesting thread this! i might get my old kyosho gx12 going and try some stuff out. will it run if it has very little compression? i just need to find some way of loading it, as it won't fit in my firestorm.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 01-08-2008, 05:06 AM   #25
rcfoolz's Avatar
larger exhaust case bore, brings on more mid and top end. When you have to run a "pot belly" tank in oval, you had to get creative.
Old 01-08-2008, 10:57 AM   #26
MugenDrew's Avatar
Found my gallon of Benzene, and its still fresh. Strips paint on contact. I was given two of these at the track on Sunday, you know to inspect them and make sure there Legal. Found out who the O.E.M. is and they are e-mailing me the "blue prints. Should have them today! I'll tear the new un-run one down tonight and the other one I'll strap to the test bench and we'll see what we are dealing with here. One is from an older car the other is from the Ferrari which I think is supposed to be the latest.
Old 01-08-2008, 02:09 PM   #27
i had a go at porting my old kyosho GX-12 engine today. it might not ever run, so i thought i could use a little practice. i noticed the sleeve exhaust port was smaller than the one on the case, so i did my best to even them out (got bored and just did the edges a little bit) and i filed down the connecting rod. i might try some of this on my G3.0 in my firestorm, but we'll see if i can get it out first! (stripped screw GRRRR)
so, how much should i largen the exhaust port by? a little bit? or alot?
Old 01-08-2008, 05:08 PM   #28
MugenDrew's Avatar
Roelf, last head button pic. Did ya get a little tight on the clearance Clarence or did she lean out on you?
Old 01-08-2008, 05:18 PM   #29
quietstorm76's Avatar
Originally Posted by Jspeed View Post
Very interesting stuff.
I asked because we're racing the Kyosho Inferno GT cars in a Spec class and wanted to gain some knowledge about the subject.
Some people have been talking about timing mods to the stock .28 IGT engine. I feel they cars rules shouldn't allow these types of mods because it is intended to be an entry level and level playing field for all.
Thanks for the educational info
I agree, leave this class alone. If they want to go faster move to a different class.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 01-08-2008, 06:22 PM   #30
rcfoolz's Avatar
if doing the sleeve port, just a little bit will help....take the upper corners and go straight out, not up in an angle, just out......
If your doing the case, I tried to enlarge it by 2mm....ie: ID 12mm...go to 14mm
Nitro Engine Sell Great Parts engines. CHEAP NitroLuver R/C Items: For Sale/Trade 2 08-19-2008 10:00 PM
Engine Timing Issue jameslow Onroad Nitro Engine Zone 4 05-08-2008 07:16 PM
engine timing and duration guage rcosmax Onroad Nitro Engine Zone 3 12-04-2004 10:46 PM
ftrc10gt and xxxnt both with engines for trade for nitro touring with engine tony montana R/C Items: For Sale/Trade 1 06-06-2004 11:09 PM
Changing Nitro % - How To Adjust Carb thefuzzclub Nitro On-Road 3 07-08-2003 06:08 PM
