Motor compression by hand???
Hey guys.
I bought a O.S RG .21 from a guy that said it had new bearings and was pinched. With the flywheel on how hard should it be to turn the motor over? I can turn it over almost with ease. There is a bit of resistance at TDC. Not alot? The motor has not been ran since the pinch. Should it inprove? What about a higher end motor like a RB. Should it be able to tunred over by hand? Thank you for all your help. |
If it was pinched, it should have resistance when close to TDC. If it was a light pinch, with no metal scratchiness at TDC, then it should have a lot of compression, and should push back when spun past TDC. Turn & hold the crank at the compression point and place the engine body at a 3 o'clock position. If it has good compression it should hold the engine case at the 3 o'clock. If the compression is low, then the engine will continue to turn and end up at TDC.
Originally Posted by ezveedub
(Post 4004102)
Originally Posted by Mpowerz
(Post 4004181)
Great tip... The motor makes it way down from the 3 o'clock postion. Does that mean the pinch is no good?
want to unload the engine? i am in need of some parts
