Old 11-26-2007, 09:50 PM   #1
Trader Rating: 13 (93%+)
Default Engine bearing maintenance questions
Hi all
I would like to start a thread about engine bearings and mainetenance.
The first question i have is how often should engine bearings be replaced? (this is referring to .12 on road nitro racing)
How do we check or what signs tells us our bearings need to be replaced.
Thanks!
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 11-26-2007, 09:57 PM   #2
PROVK's Avatar
Trader Rating: 14 (100%+)
1.Lateral movement is the most important sign to look for, this creates air leaks which leans engine
2.Gritty rotation
3.Visibly rusty and dirty
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 11-27-2007, 08:05 PM   #3
Moderator
mxwrench's Avatar
Originally Posted by mrgsr View Post
Hi all
Thanks!
I'd say for sure no longer than 10 hrs (at an average rpm of 35,000 for 10 hrs that is like 21,000,000 revolutions on that poor little bearing!!)
I like to change mine every 5hrs. Cheap enough insurance to make sure your engine is running it's best.
I also change the rod at 5hrs wether it needs it or not, so that may just be me.
The previous post is very good advise for signs of wear. Primarily lateral movement or looseness of the race, then check for gritty feel (although this will usually mean dirt or contaminants like metal from glow plug element, piston material, material from crankcase caused from crank rubbing etc.) All of which are very bad!
Make sure to use a fixture or oven to install your new bearings as one time with a hammer (very likely to install bearing crooked) and your crankcase WILL be junk and will need replacement. USE A FIXTURE!!!
Slightly loose bearing fitment to the crankcase can be fixed with red locktite on outer race surface when installing new bearing (however if this is used the oven install technique is no longer an option!) USE A FIXTURE!!
Thats pretty much all I have to say about that...
BK
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
Bearing maintenance scarymonster Electric On-Road 7 10-01-2007 08:03 AM
Bearing maintenance scarymonster Northwest Racers 4 09-30-2007 09:32 PM
Bearing maintenance AMGRacer Nitro On-Road 15 07-30-2007 04:54 PM
Bearing Maintenance Mossie Australian Racing 38 07-13-2004 04:54 PM
Bearing Maintenance S15Racer Electric On-Road 3 05-01-2004 09:54 PM
