Old 11-14-2007, 07:30 PM   #1
Default After Run Oil
Hi good people!
A buddy of mine told me that instead of using 'after run oil', one can use '2t or 4t motorcycle motor oil'....how true is this?
Your advices/experiences, good people, is highly appreciated!
steponit! is offline   Reply With Quote
Old 11-14-2007, 11:56 PM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
You want to use an castor based oil which can be mixed with methanol, most castor oils can but if you do a search for special oils for methanol engines.
But why ?
One tiny bottle afterrun can go for a long time.....
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 11-15-2007, 09:41 PM   #3
CurveTracer's Avatar
Petroleum based fluids will deterioate the o-ring seals in some engines. It would be safer to stick with castor based after run oils.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 11-15-2007, 09:48 PM   #4
Mugenville's Avatar
Trader Rating: 25 (100%+)
Save yourself some money and buy a bottle of transmission fluid works a treat
Mugenville is offline   Reply With Quote
Old 11-16-2007, 05:53 AM   #5
Taylorm's Avatar
......been using Marvel Mystery Oil for years.............seems to work great, no rust anywhwere............
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 11-16-2007, 08:51 AM   #6
TeeKuang's Avatar
I just use ATF, it's because ATF is an excellent anti oxidation oil and contains high amount of detergent to clean engine's internal.
Best Regards, Tee Kuang
Rovan 290S
Killer Bee Kill switch | Outerwears | hydraulic brake | Ace DS-1015 |ADA Rear billet hub bearing carrier | Hostile Nightmare MX | RCMOD Closed clutch |
Gasoline POWER : Malaysia Large scale hobby
TeeKuang is offline   Reply With Quote
Old 11-16-2007, 09:14 AM   #7
Davidka's Avatar
Trader Rating: 77 (100%+)
This and the ATF suggestion are both great choices. One thing to be careful of: If you have a "slugged" crank (one that has been lightened and has a silicone plug in the intake area) you must not use either of these. Use good ol' fashioned mineral oil only. Petoleum oils will eat that silicone plug fast.
Old 11-16-2007, 10:48 AM   #8
TeeKuang's Avatar
My IDM engines has filled cranks, no problem using ATF. just avoid WD-40, it will dissolve crank putty.
Rovan 290S
Old 11-17-2007, 09:09 AM   #9
Thanks a zillion, good people! Really appreciate that!!
Old 11-18-2007, 08:17 AM   #10
TOMJR's Avatar
what about those Tamiya engine treatment spray ?
Been using it seems pretty good.
Anybody here try it ?
TOMJR is offline   Reply With Quote
Old 11-18-2007, 06:04 PM   #11
horizon644's Avatar
The Tamiya Treatment spray is good and does not ea the silicon puty in the crank. Its basically Fuch's based Mineral Oil that is bottled in a spray can. It's viscosity is lower than engine oil, thus it does not leaves a thick coat of oil in your engine. Pros" It leaves a thin coat of protectant in your engine." Cons: " You pay alot more for it "
Acorn Innovations
- From Little Acorns; Mighty Oak Trees Grow.
Acorn Racing
www.acornracing.com
Email: [email protected]
horizon644 is offline   Reply With Quote
