Old 11-08-2007, 09:32 PM   #1
JZL
Questions?? .12 Jamming Turning on Backwards
Hi, new to the forum. My friend has a cd3 with a .12 Jamming motor on it. Yesterday we turned it on but the box start motor was inverted so he accidently turned it on backwards. Now it turns on easily but backwards. Any advice? We have tried adding more shims, reducing nitro fuel % from 30 to 20, and using a diffrent glow plug with no results. What do you guys recommend?
Thanks in Advance, Any advice will be appreciated
JZL is offline   Reply With Quote
Old 11-08-2007, 10:17 PM   #2
JZL
I was just looking at a picture of the motor online and my friend has the carb reverse to what it looks like in the picture. The needle is on the left and the slide mechanism is on the right, could that be the problem?
Old 11-08-2007, 10:32 PM   #3
thamjk's Avatar
if you are looking at the front bearing, the carnkshaft should turn anti-clockwise direction. Which direction you are now seeing the shaft turning?
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
Old 11-08-2007, 10:46 PM   #4
JZL
Were turning it clockwise. Since when we roll the car on the floor the flywheel turns clockwise. Is this correct?
Thanks for responding.
Old 11-09-2007, 02:33 AM   #5
German Muscle's Avatar
the engine runs counter clockwise when looking at the front bearing and carb. The engine wont run the other way other than idle.
German Muscle is offline   Reply With Quote
Old 11-09-2007, 11:45 AM   #6
JZL
Ok thanks, We were trying to turn it on clockwise, and my friend also had something wrong with the differentials.
Thanks for all the replies.
Old 11-30-2007, 11:04 PM   #7
LogiK's Avatar
Trader Rating: 11 (92%+)
Well its not going too.. Learn to read please..
Reverse the polarity on either your rotostart or your starter box, making the motor spin the other way.. This will solve your wheels spinning the wrong way too.
LogiK is offline   Reply With Quote
Car Running Backwards amx Nitro On-Road 20 01-30-2010 11:36 PM
Help - car running backwards TC3ElectricGuy Rookie Zone 16 08-16-2008 07:23 PM
Backwards FTW? Ashley Cobb Nitro On-Road 2 03-31-2008 01:20 AM
wtb 16mm bigbore shocks buggy,ofna/jamming etc fastboy R/C Items: Wanted to Buy 0 01-29-2008 05:51 PM
Need Help With a Backwards Chameleon 2!!! Glowster21 Electric On-Road 9 11-17-2005 03:14 AM
