Old 10-28-2007, 03:27 PM   #1
avs
avs's Avatar
Default help with needle's o-ring replacement
this may seem trivial, but it has become really frustrating, i would really appreciate if anyone has developed a scheme for replacing the o-ring on the main ( high speed) needle.
so far i have either torn or split 4 trying to put a fresh o-ring on a high speed needle. specifically this happens to be a RB C5 main needle using the 1270 rubber part.
putting it on the long way over the threads seems to chew up the inside portion, while taking over the screw head breaks it. my next step is to soften the edges on the screw head, my suspicion is the sharp edge is cutting the rubber?
thanks very much for any tricks.
avs is offline   Reply With Quote
Old 10-29-2007, 01:43 PM   #2
GMartinez's Avatar
Trader Rating: 85 (100%+)
Before you install the O-Ring lube it with any type of oil that should help you out
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 10-30-2007, 11:33 PM   #3
avs
avs's Avatar
thanks for the tip.
i had tried a light oil and grease but the ring breaks.
Old 10-30-2007, 11:54 PM   #4
Team Kamikaze's Avatar
Try soaking the o-ring in boiling water for 1 minute, it will make the rubber o-ring more elastic which will stretch over the needle when installing also coat the threads with grease. "CAUTION IT'S HOT" try not to burn yourself .
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Ring Tones!!! tmail55 Chat Lounge 2 08-25-2007 08:19 PM
RING THAT BELL Leodis Chat Lounge 11 08-23-2007 07:50 AM
Replacement Airtronics 94758 replacement case rcguy2477 Electric On-Road 1 02-25-2005 05:46 PM
IRS D-Ring diff disaster999 Electric On-Road 0 01-19-2004 11:21 PM
