Old 10-25-2007, 11:25 PM   #1
navigns's Avatar
Default help with removing screws from engine head
any tips for the aboved?
two out of four screws connecting the crankcase and cooling head allen head screws are stripped.
please share how can i remove them
__________________________________________________________________________________________
-powered by SIRIO-
navigns is offline   Reply With Quote
Old 10-26-2007, 12:56 AM   #2
The easiest way I have found is to just drill the heads off like you would when removing a rivet. Then you can lift the heat sink off and un-screw whats left of the bolt with vice grips, or equiv.
Vic Rattlehead is offline   Reply With Quote
Old 10-26-2007, 03:01 AM   #3
JetMD's Avatar
This may sound dumb but make sure you're using metric allen drivers. Also, make sure the allen driver has nice sharp edges on it. If it looks worn, take it to a grinder (or dremel will work) and cut the worn part off. If it's a ball head, get a flat one and try that. If it still don't work, i've used a dremel before to cut the head of the bolts off from the side. You'll scratch the cooling head somewhat but you gotta do what you gotta do. That's why I don't loc-tite those bolts. Just gotta remember to check them every race.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 10-29-2007, 06:50 PM   #4
navigns's Avatar
wow, great tips..tks so much, i manage to get the screw out, but this time i stripped the screw thread in one of the four holes below the rear exhaust, back plate, if thats what it's called. i used too much force while tightening screw
do i have to change the whole crankcase because of 1 loose hole?. it sounds expensive to do so
share some tips guys
-powered by SIRIO-
Old 10-30-2007, 01:17 AM   #5
ShrekNZ's Avatar
I've been running an old Nova with 2 screws for sometime with no leaks
ShrekNZ is offline   Reply With Quote
Old 10-30-2007, 06:04 AM   #6
You can use what's called a Heli-Coil threaded insert to repair the threads. I recently bought a 4-40 set that included the special tap, 10 inserts and installation tool for about $31.00 U.S.
I got it from McMaster-Carr
They also come in metric sizes.
Old 10-30-2007, 08:56 PM   #7
Moderator
mxwrench's Avatar
Here's a cool little tip for those trying to get out a rounded socket head screw (allen type) (and I think it might work for flat blade type as well).
Get some coarse valve lapping compound at the local auto parts store (clover is a popular brand) and coat the tip of your hex tool with it. Try and remove screw. If it is still stuck, try and heat the head to 200 deg with heat gun. That should do the trick.
The carbide in the lapping compound will decrease the gap and also increase the grip of the tool.
Give it a try before hacking the head off with a dremell.
BK
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
flat head titanium allen head screws lidebt2 Electric On-Road 4 07-25-2008 03:17 PM
Removing stripped screws Colby Rookie Zone 6 02-07-2008 01:05 PM
removing damaged screws 32819toon Nitro On-Road 11 07-28-2007 05:51 AM
Removing stripped screws? cannon_eer7 Singapore R/C Racers 4 10-24-2005 09:10 AM
Removing Impossible Screws! LosiFromHell986 Electric Off-Road 20 08-23-2004 03:23 AM
