Old 10-07-2007, 05:20 PM   #1
Default air leak
hope someone can help. i have both an ae .15 and an xtm .18 engines. i tested then for air leaks by covering the carb with my finger and blowing into the fuel inlet, then brushing soapy water over the engine. both engines leak around the base of the carbs and the around the bolt you use to tighten the carb to the block. i know a new o ring will seal the carb, but how do i seal around the bolt?
thanks
mike
mjnp06 is offline   Reply With Quote
Old 10-08-2007, 04:56 AM   #2
CraigM's Avatar
Trader Rating: 34 (100%+)
Yep I'm about to fix a similar leak. Use RTV sealant for the carby and the bolts
here's a good article http://www.rchobbies.org/engine-tuning.htm
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-08-2007, 06:16 AM   #3
Taylorm's Avatar
thanks
mike
..........place a new o-ring at base of carb and use Permatex Ultra Copper.....just enough to make a good seal...
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 10-08-2007, 10:59 PM   #4
CraigM's Avatar
how soapy the water needs to be? I nearly busted a lung trying to find a leak last night but I never saw any bubbles. Starting to think the carby might be air tight
Air leak help Mustang2 Electric Off-Road 1 10-29-2006 01:35 PM
I think I have an air leak? Dishy Nitro On-Road 1 06-26-2006 04:38 AM
Nova Rossi engine Air leak or fuel leak? Solara Nitro On-Road 15 01-21-2005 04:00 AM
Possible Air leak? HELP! Smoke21 Nitro On-Road 2 08-06-2004 12:25 PM
Is it a leak??? hicheef Onroad Nitro Engine Zone 1 06-28-2004 01:49 PM
