Old 09-20-2007, 04:44 AM   #1
Trader Rating: 13 (93%+)
Default Inner button head - polishing after engine has been pitted
Hi Guys
Just wanting to know if its good to lightly sand/polish the inner button head after its been pitted?
should i replace the head instead?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 09-20-2007, 04:45 AM   #2
I forgot to mention ive done this to this engine once before
Old 09-20-2007, 06:20 AM   #3
Originally Posted by mrgsr View Post
Hi Guys
Replace the head button... A pitted head button is due to a bad tune and by sanding/polishing it, will cause your motor to loose compression as well. Your head clearance will be off and most cases the button will not seal with the sleeve properly either... For what $10.00-$15.00 USD, go buy a new head button, run the proper plug/nitro% combination, run a tune pipe more suited to the motor you're running, don't run your motor out of tune/to lean... and you won't have anymore pitted head button issues... Your motor will run faster, your glow plugs will last longer and your motor will be happy you did...
RC_Alan
rc_alan is offline   Reply With Quote
Old 09-20-2007, 06:47 AM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
No problem to do the rough part with waterproof sandpaper and the rest with a multitool with a polishing bit.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 09-20-2007, 07:30 AM   #5
I polished up the button with some real fine sandpaper then polished it up with aluminium polish, ill see how it goes on the weekend.
Old 09-20-2007, 10:54 AM   #6
Trader Rating: 93 (100%+)
Default Polish
I think you can polish it and it will work fine. If you read the plug you can shim the head properly.
latemodel13 is offline   Reply With Quote
Old 09-20-2007, 02:33 PM   #7
wallyedmonds's Avatar
Replace it
wallyedmonds is offline   Reply With Quote
axe mamba head button... SteveJa Nitro Off-Road 0 11-30-2007 06:31 AM
WTB: Engine Head Button d4_racer Australia Wanted to Buy 4 04-10-2007 11:30 PM
Looking for button head for M12 engine TC_Tuner R/C Items: Wanted to Buy 0 07-17-2006 09:07 AM
Want .21 head button. shadmaster4 R/C Items: Wanted to Buy 0 06-19-2004 11:03 AM
Looking for Head and Head button for MT12 std plug Deltaman R/C Items: Wanted to Buy 0 07-15-2002 10:53 AM
