Old 08-20-2007, 03:39 PM   #61
Lokanas's Avatar
Default v2007
I ran Orion 2007 version. Mine is already dead, but couple of my friends still run those . If the track you're runnin' in isn't crampy - this motor is really awesome. Otherwise it's a bit tricky to drive with late engaging clutch in VERY tight turns.
Maybe it's a good thing to reset it to factory settings when you get it out of the box - mine was off.
Lokanas is offline   Reply With Quote
Old 08-21-2007, 12:37 AM   #62
Nano's Avatar
Lokanas, how many liters has your engine run? weird to hear that it's dead?
About the clutch, CRF test track is as "crampy" as it gets. The 2007 has more low end so it should not be a problem on any track.
Nano
Nano is offline   Reply With Quote
Old 08-21-2007, 06:29 AM   #63
Nano
i loved this engine on the 2006 tourer worlds track..can't complain
TomB is offline   Reply With Quote
Old 08-21-2007, 09:40 AM   #64
Lokanas's Avatar
Nano
I ran around 3.5L (tornado 16%). It was overheating (or running hotter comparing to other CRF's) since the very run-in. I never found out the reason, but never let the engine run too lean. Checked for air leaks several times - found none.
Anyway, the engine helped me to win couple races so i never blamed it Probably i just overlooked something in settings and that was a killing factor.
The very "worst temp" it ever get was 147C (i know it's already a bit too much). Usually it ran ~107-120C (and boy i had to richen it to keep the temp down).
PM me for details if you want.
No matter what happened to mine - i really liked the engine. Nice piece of machinery and revvy powerband
Old 08-21-2007, 11:01 AM   #65
Hi Nano,
Could you give any input on this one?
http://rctech.net/forum/attachment.p...5&d=1187032164
Is piston to far out of cylinder and i have to put a new set in, or should i just try to work with carb settings to get idl more stable?
As at the moment, after it gets hot, it just flames out of throttle all the time.
At the same time, idl is perfect, when temp is low, as soon motor gets ~5min of track time, flame out happens.
JanisK is offline   Reply With Quote
Old 08-22-2007, 02:50 PM   #66
rmdhawaii's Avatar
I can get this engine for $264 + shipping. Anybody know where I can get it cheaper.
BTW.. I do want the Kyosho version.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 08-24-2007, 05:23 PM   #67
yesterday, i have run in my new kyosho engine.
factory setup whas total bad, engine did not run.
i must srew out hsn and lsn.
after break in, engine are powerfull but after running 5 tanks
engine flame out
i change clutch setup, but he same problem.
after flame out, engine restart ok, good idle. temp not over 100C
can anyone help me??
dieter
PS:i drive a mugen mtx4 wc, kyosho crf engine with kyosho pipe
4racer is offline   Reply With Quote
Old 08-25-2007, 03:44 AM   #68
engine flame out
dieter
you need to tune it man. go very rich, then see what it does, then go very lean so you know how the engine acts at both extremes.
Old 08-30-2007, 02:56 PM   #69
kaotickc's Avatar
Trader Rating: 43 (100%+)
Anyone in the U.S. carry this engine yet ?
kaotickc is offline   Reply With Quote
Old 09-01-2007, 02:48 AM   #70
anyone found that the screw that holds the carby pinch bolt doesn't hold the carby tight enough?
i thightened down my carburetor after it came loose, and had another look at it today, and i was able to move it with my hand
why did CRF/Kyosho use such a thin screw, with a small head on it? (1.5mm head with the screw diameter being 2mm i think)
i sealed up the carby with gasket sealant as well as sealing up the pinch bolt but if you use alot of brakes i can see the thing coming loose eventually again
Old 09-01-2007, 02:53 AM   #71
itchy b's Avatar
That's what you get for putting a Kyosho engine in a Mugen!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 09-01-2007, 03:25 AM   #72
rmdhawaii's Avatar
This has happened to a few people, including myself. Here is why:
http://www.rctech.net/forum/showthre...31#post3328931
The retaining doesn't work like it does on other engines. Once the glue cracks, trying to tighten the retaining screw so that the carb won't rotate will just strip the screw. I've done this twice already. First time because I thought the screw worked like other screws. Second time because I didn't know about the glue thing.
I haven't gotten around to fixing it again because I've been running the STI. Nano didn't say what specific glue to use, so I'm hoping JB Weld (slow cure) will do the trick. I'll probably get around to it next weekend.
BTW.. You have to cut off the insulator to get it off.
Old 09-01-2007, 06:41 AM   #73
ok i'm hoping the glue hasn't cracked. i've already sealed up the carby, so i don't want to tear it apart, and im hoping kyosho remedied the problem already....still not sure why they used such a stupid little fricken screw!!
Old 09-11-2007, 12:17 AM   #74
CraigM's Avatar
Trader Rating: 34 (100%+)
Damn that sucks! I also don't wanna have to dremel my motor to make it fit! Has anyone successfully put this motor into an MTX4R without modification? I don't want to have to shim it up either
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-11-2007, 05:55 AM   #75
if you have a standard sway bar on the 4 you won't have to dremel the middle needle head, but you will still have to dremel the carby so the break disk does not hit.
yeah, i guess having the name kyosho on it, maybe they did the design on purpose to piss mugen guys off
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
