Old 07-12-2007, 11:29 AM   #31
va_connoisseur's Avatar
Send a message via Yahoo to va_connoisseur
Originally Posted by GBagRacing View Post
I started initial break in of the engine today. It's the only engine I haven't had to restart several times during the first tank. Coupled with the 2630 pipe & the engine set massively rich it took about 60 seconds to drain the tank. I'm going to have to wait till after the weekend before I have the time to get it in the car and begin the heat cycles. I can feel a very large smile about to happen.
Letting it sit for several days will not negatively effect the run-in procedure?
va_connoisseur is offline   Reply With Quote
Old 07-12-2007, 04:24 PM   #32
Nope! It needs heat or moisture to change it's molecular structure. Otherwise it will remain as is till the next run.
GBagRacing is offline   Reply With Quote
Old 07-16-2007, 06:32 AM   #33
OK. Started the heat cycle run-in method. Ran into a problem when I went to take it to the track, throttle servo D.O.A. Do the engine has 6 rich tanks through it with temps between 175 and 190. When the new servo gets here will complete the run-in process.
Old 07-20-2007, 11:18 AM   #34
Well so far so good. 1/4 way through the first part of the rolling break in (3 tanks : 6 total) and all is well. Had to wrap the head in a rag to get the temps up to the 200 deg range and only 2 flame outs so far. This looks to be one of the easier break ins I've done.
Old 07-21-2007, 10:39 AM   #35
WOW! 4 tanks to go. Still 4 stroking & drooling but it's right on the edge of starting to come alive. Im using 26mm rubber tires for the break in & it's very close to spinning them with a 1/2 throttle pulse.
Old 07-23-2007, 02:56 AM   #36
any idea how is the RB matrix RW performing ?? as i just got one still in the box.
ExtremeEvo9 is offline   Reply With Quote
Old 07-23-2007, 05:47 AM   #37
M7H
M7H's Avatar
Rubber tires....
M7H is offline   Reply With Quote
Old 07-23-2007, 06:09 AM   #38
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
all i got to say is a stock RB R3 was keeping up with my Murnan Nova Plus 12-3CT so these things are nuts i couldnt get over how quick these things are any one who has one look out
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 07-23-2007, 10:41 AM   #39
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Grinder... Which break-in method do you suggest to go with this engine???
Riketsu is offline   Reply With Quote
Old 08-21-2007, 09:18 AM   #40
Ok just an quick update. I've just finished my 2nd race weekend with the Murnan R3 / Nova 2630 pipe combo. This motor has some very serious punch. I'm still running fat as I believe the secret to a long lasting motor is a long slow break in. This week the motor was faster than last week and I used the same basic tune it came with till the main then made it 1/8 turn richer on the bottom & 1/8 leaner on the top. The engine is still pouring out smoke like crazy & drooling plenty of oil out the exhaust. It was still strong enough to get me a 3rd place (I chased set up all day & felt the final set up was where I should have started my day). All in all I am very satisfied with this engine so far.
Old 09-03-2007, 09:42 PM   #41
SlamMan's Avatar
Hey guys. I'm looking for some replacement o-rings for my R3. I noticed the top needle on my R3 has 2 o-rings where as the exploded diagram seems to show a needle with only 1 o-ring. Are the part numbers in the exploded view correct?
Has anyone been able to find the R3 o-ring maintenance kit?
SlamMan is offline   Reply With Quote
IDM Products? rcrevolution Onroad Nitro Engine Zone 717 03-03-2013 03:52 PM
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
cen products chifan26 Nitro On-Road 7 09-19-2005 02:50 PM
