Old 06-15-2007, 04:40 PM   #16
quietstorm76's Avatar
I thought they were using sirio now.
quietstorm76 is offline   Reply With Quote
Old 06-17-2007, 08:42 AM   #17
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I hear the pricing will be around $330-$350. If it's as fast or faster than the Nova plus .12 then that's a good deal.
HarKonnenD is offline   Reply With Quote
Old 07-03-2007, 08:57 PM   #18
Well .... I broke down & bought one of these........the murnan modified version....along with the nova pipe they suggest using it with... I'll keep ya posted on how it goes.
GBagRacing is offline   Reply With Quote
Old 07-04-2007, 07:11 AM   #19
HarKonnenD's Avatar
Gbag - Awesome! Definitely let us know how it runs.
Old 07-04-2007, 09:32 AM   #20
Grinder's Avatar
I think you will be happy. The modified version is very strong. The engine seems to be very reliable as well. I have almost 2 gallons on my test engine, and it keeps getting faster, and still tight. The engine seems to have similar bottom end to the +12 engines, with more power up top than the +12. The engine revs to 45,000 rpm easily on the dyno. The break in is slow with the engine. Just like the +12.
The Piston/Sleeve/Rod is interchangeable with the +12 engines. The engine also features a 3 needle carb, which I like. The engine has a lowered cooling head. The head button also has the O ring, and the case, and cooling head have the lightening holes drilled like the 353.
Grinder is offline   Reply With Quote
Old 07-07-2007, 06:36 PM   #21
va_connoisseur's Avatar
Send a message via Yahoo to va_connoisseur
I just picked up one of these beasts. I have yet to pick pipe, do anyone know where I can get the RB recommended pipe? Thanks.
va_connoisseur is offline   Reply With Quote
Old 07-08-2007, 08:24 AM   #22
Grinder's Avatar
You want the Novarossi 2630
Old 07-08-2007, 12:21 PM   #23
stefan's Avatar
Send a message via AIM to stefan
Uriah,
do you feel that all of these pipes are performing the same?
I had three, and two were not doing anything, while the third made my 12-3ST scream
stefan is offline   Reply With Quote
Old 07-09-2007, 06:47 AM   #24
CIMRI's Avatar
Originally Posted by stefan View Post
Uriah,
Intresting. Did you use with same manifold?
CIMRI is offline   Reply With Quote
Old 07-09-2007, 02:20 PM   #25
I decided to go with the pipe RB recommended. Should be here Wednesday. I was reading the Running-in Procedure and it steps through nine (9) tanks before you begin to tune for performance.
When I am running on the track, tanks 2-8, should I have the body on or off the car? They are not specific. Thanks.
Old 07-09-2007, 02:59 PM   #26
stefan's Avatar
yes, I did
Old 07-09-2007, 03:00 PM   #27
stefan's Avatar
Which pipe are they recommending?
Old 07-09-2007, 07:42 PM   #28
They suggest the 01751-401 pipe and 0175-195 conical short manifold
Old 07-09-2007, 08:26 PM   #29
Grinder's Avatar
Uriah,
Hi. I have been through more than I care to count. They all seem to perform the same. Did you try them on the same engine? I know they changed the header design slightly just after the pipe was introduced. The short header that used to come with the pipe did not have any fins, now the pipe comes with the 5 fin header. Maybe they are making running changes to pipes too. Maybe changing the baffle holes slightly. I do know the pipe does not perform as good after it is dented from a crash.
Old 07-11-2007, 03:08 PM   #30
I started initial break in of the engine today. It's the only engine I haven't had to restart several times during the first tank. Coupled with the 2630 pipe & the engine set massively rich it took about 60 seconds to drain the tank. I'm going to have to wait till after the weekend before I have the time to get it in the car and begin the heat cycles. I can feel a very large smile about to happen.
IDM Products? rcrevolution Onroad Nitro Engine Zone 717 03-03-2013 03:52 PM
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
cen products chifan26 Nitro On-Road 7 09-19-2005 02:50 PM
