JP FX21B-8T
Im geting one of these engines and would like anyones opinion likes, dislike's, preformance, fuel Consumption, how easy to tune
http://www.jpracing.com/img/products...r/fx21b-8t.jpg Technical Data FX 21 B-8TC. Capacity :3,49 ccBore :16,26 mmStroke :16,80 mmPorts :8 + 2 By passCrankshaft :ø 14 mmCarburetor :ø 8 mm + reducerGlow Plugs :TurboWeight :385 gr# FX 21 B-8T http://www.jpracing.com/img/products...t/fx21b-8t.jpg Turbo Glow Plug Turbo Glow Plug for best performances. http://www.jpracing.com/img/products...e/fx21b-8t.gifhttp://www.jpracing.com/img/products...n/fx21b-8t.jpg 8 ports ABC Sleeve This 8 ports sleeve is revolutionary in the Off-Road engine’s range. The exhaust has two boosters in order to increase performances and manage the fuel consuption on the best. The last generation conrod is lightened with 2 bushings. The piston is also pierced to decrease the piston temp. http://www.jpracing.com/img/products...n/fx21b-8t.jpg Turbo Crankshaft The modified and lightened crankshaft is filled with the special red putty which is positionned to improve the gas passage. In order to reduce the friction and the wear, the crankshaft is HardBlack coated. The Turbo design of the crankshaft's head highly improves the engine power. For best performances ! http://www.jpracing.com/img/products...r/fx21b-8t.jpg Carburetor The special Off-Road carb is made of plastic in order to avoid the «vapor-lock». As all FX Engines, it has a simple adjustment (1 screw). The adjustment is easier |
If this is JP`s version of the Novarossi 421B i would buy the 5 port version instead.
The 421 was difficult to tune, did not hold a tune very good, average fuelconsuption, good bottom and top end. I would rather buy a OS V-spec speed or an Rb C6BB |
These engines are awesome but are more suited to fast tracks.Anything technical and lots of jumps then the FX21B-5T is much better.
The 8T has more legs on the top but how long are you at high rpm on a track.If you do use it id suggest going to a 13t bell or even 12t bell. |
thats a Novarossi S821B. Ive seen a AB Mods one up against a JP Modded one like the one above, and the AB Mods had a little bit more power all around. It was also getting 10 minute runtimes on a big euro style track in a XRAY.
Pics http://i3.photobucket.com/albums/y55...sleevepic3.jpg http://i3.photobucket.com/albums/y55...sleevepic1.jpg http://i3.photobucket.com/albums/y55...sleevepic2.jpg http://i3.photobucket.com/albums/y55...kincasepic.jpg Vid http://www.abmods.com/videos/buggy2.wmv |
thanks guy's much appreciated :)
nice vid 2 is it posible to get it with out the music so i can hear the beast scream :D
BTW i love the Track its off guts! were you geting 10min out of the AB or the JP |
10 minutes on the AB.
I might still have the vid before i had German throw some music in it for me. I'll have to look around my PC. :) It was very hard for me to pin it full throttle as it was sooo loose and dry out there that day. But i did pin it a few times about midway down the backstretch :nod: It didnt help i had some old tires from a sportwerks RTR buggy on my Xray either... My modified 821 is deffinatly 1 of my top choices for a .21 :nod: great bottom mid and top end using a 53 pipe. And great fuel consumption to boot!
cheers man that would be awesome :D
you wouldnt have any dyno runs of either the JP or AB version |
you wouldnt have any dyno runs of either the JP or AB version PS. I found the vid with no music... uploading it now. |
Nice :)
Wow 149MB :eek: comparied to 12.9MB this version is gonna be heaps clearer :tire: thanks Colt
OMFG how is the thing its off its F@#%ing head :tire:
I love these engines after i do my modifications to them. Like i said its deffinatly one of my favorite all around .21s I also use it in my 5T truggy. It has PLENTY of power for it. Most everyone runs 21s out there. And the 821 puts it on em :sneaky: Get with me if u want one done up :)
OK cool do you do onroad engines as well
(Post 3360749)
I really like these TC3s for the parking lot tracks around here. They work very well in the lots IMO. http://www.youtube.com/watch?v=WSYSPCjL4e4 |
very nice might have to send you me Ninja to work your magic on :sneaky:
(Post 3362923)
I own one of these beasts.
In a buggy its excellent, very linear powerband with a wicked upper midrange and topend. I used it in my truggy and it lacks the bottom end for a truggy. If you use it with a werks clutch and adjust for later engagement then it will work. This is apparently JP's most powerfull engine. The internals are top notch. The casing inside has been worked, the crank is a work of art. The sleeve porting is beautifull. I changed the sleeve with a P5 sleeve and must agree with razzor that the 5 port is a much better option. You can use any P5 sleeve and it will work in this engine. At least keep the option in mind. With the 5 port sleeve this engine uses more of its power. With the 8 port you get to 3/4 of the straight and it wants to only start delivering. |
Originally Posted by Jerseyboy
(Post 3369930)
which break in process best suits this engine
WOT method http://www.cefx.net/tips/nitro/break-in/index.php Or heat cycle http://www.johnnycoolguy.com/JCGR/ma..._break-in.html |
Heat Cycle
Ok i was thinking that one but just wanted to make sure
Got a 5-T yesterday along other niceties just to try it with my 'Moguls Panzer' (aka MBX5-T) wanted to try one of those just to compare it with the Ninja B01 I have since day one.
This weekend is impossible to test it, but, next weekend I'll be breakin-in just to see how flexes their muscles and compare them with the B01. Got the EFRA 9901 pipe along the std long manifold (double turn). Any comments regarding this combo? Many swears by the 9886 pipe, but.. is very hard to find actually here (too loud!). |
This engine works best with Novarossi 9886 or 9853 tuned pipes. The 9853 tuned pipe will provide more power on the bottom end with about the same top end as the 9886 pipes, however runtime will suffer. The best overal pipe for excellent runtime with smooth power delivery is the Novarossi 9886 with short header. The longer header will give a little more bottom end at the expense of runtime. The MSR1005 pipe also works well on this engine, but it also suffers from less runtime than the 9886 tuned pipes.
Originally Posted by Corse-R
(Post 3374846)
Hers a link to some reviews in the offroad section
http://www.rctech.net/forum/showthread.php?t=110390 |
what oil content is recommended with this engine novarossi web sit states to run a max of 10% oil in their engines thats what i have got for this engine will that be ok?
(Post 3376526)
Vendors doesn't state how much oil and which oils, but... should be around 10%. Few (very few...) state them. |
i noticed that no well named brands state their oil content I'm using AT Racing with a 25% nitro and a 5/5 oil mix i use it in my onroad 1/8 as well should be OK
Thanks Corse-R |
OMFG this engine has been the easiest engine to run in not one flame out even with the HSN half a turn out from stock it wants to start screaming about half way through the process gonna finish it tomorrow this thing is going to be nuts when its fully tuned :eek:
finished up running in me engine very pleased with it, it's one of the best engines to run in it has been very kind to me almost got 2 liters threw it still got to race tune it she's on the rich side but still goes like the clappers any one thinking of getting one of these engines don't have any doubt its very user friendly a looks like its going to be a top performer
| All times are GMT -7. It is currently 01:55 PM. |
