Can a .12 be faster than a .18 ???
Newbie question... I'm looking for a really fast motor for my 1/10 scale lightning stadium 10 4dw, while keeping things under a budget
I was going to go for an O.S. .18 CV-RX (about 28,000 RPM), since I heard great comments about it...
but then someone recommended an Ofna Hyper 12 !!! (1.4 HP and 37,500 RPM)
They both cost about the same, an the .12 has impressive numbers... but would the .12 really be faster in my truck? Perhaps I'm missing something here, but wouldn't the .18 still produce more torque and accelerate faster??
What confuses me is that the little .12 seems to produce the same or even more HP that the .18...
Get the OS 18TZ-P if you want big power!
http://www.nitrodynesystems.com/OS%2018%20TZ-P.htm
It's only 25 bucks more at tower and the performance difference is well worth the extra coin!!
BK
the answer is, it depends! I know .12's that will smoke .18's in a heartbeat.
And depending on a .21 or .28, it'll smoke the heck outta the small blocks, UNLESS, its a sport engine like much of OS's line or Toki built engines.
the .18 TZ sounds tempting...
do you think fuel consumption could be less than in the standard .18?
Problem is my tank is just 75cc so I'm afraid that a .18 will not provide lots of runtime... even with my old .15 I was wishing for a bigger tank, but I'm not sure what tank could fit in this chassis
the tz is definitely hungrier for fuel than the cv-r. Gear it right and time your pits right, you should do ok. Legally, 75cc is the limit for many 1/10 scale classes. Bigger fuel filters help gain a few seconds and maybe a lap or 2.
the purpose of the .18's are for torque, and moving those heavy traxxas trucks around the track
I know it's not in a truck but here's a vid of my 18 TZ in a CD3.I haven't seen a .12 that will walk it down on topend.
http://s77.photobucket.com/albums/j6...¤t=O.flv
Mark
Mark
possible... but then again, you are only going down a straight line.
A fast car or truck also has to do with handling.A good setup will out run a bad setup anyday no matter engine your running.Plus being a good driver helps too.If you can't drive the fastest engine in the world will not help you.
Mark
Mark
I've heard comments that this one is as powerful as some .21 and 28's out there, so in a lighter 1/10 truck it should be ballistic.
I think there's even an EBMods version of the TZ!! but then that one must be just too much for my truck.
Mark
Mark
http://www.youtube.com/watch?v=WSYSPCjL4e4
