Old 05-21-2007, 03:38 PM   #16
cosmo-hungary's Avatar
so differences between the 21MKII and 21T are
different sleeve
not conical shaped piston
crank isn't filled
here are the pics
left is the updated 21
cosmo-hungary is offline   Reply With Quote
Old 05-21-2007, 04:40 PM   #17
vr6
Trader Rating: 22 (100%+)
how about the bearings
Ko Propo. Hobbywing. Jconcepts. SMC cells
Also my local track Race em r/c. Rockford Illinois
vr6 is offline   Reply With Quote
Old 05-22-2007, 03:02 AM   #18
they are same
Old 05-25-2007, 02:56 PM   #19
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Hmmm. Not sure what to think about this one now. Looks like it would surely cost less to produce...
Artificial-I is offline   Reply With Quote
Old 05-25-2007, 03:18 PM   #20
bjc
Me too on the cost thing. As long as it goes just as hard and the crank is stronger than the old ones!
I assume the 21's dont like heat as opposed to the 28's with a thicker crank?
bjc is offline   Reply With Quote
Old 05-25-2007, 10:14 PM   #21
Kemorc's Avatar
Send a message via AIM to Kemorc Send a message via MSN to Kemorc
Ok guys time to answer your questions about this mill
Rick brake has offered the green machine with is own mods. He emailed STS quite a few times with pics and specs on how to make the engine BETTER.
So, STS took in the design, and here you have the MKII.
Rick Brake = RB Mods.
Review from Rick Brake of RBmods.net :
History and the making of a new STS MK11 engine. When testing the D21B and D21T engines my preliminary diagnosis led me to study these engines in depth and have my drivers testing them.
Everything I thought the engine would do was correct, These were great engines for the price but I thought STS could do a little better with the same amount of
effort. So after a few emails and sending them pictures on what to do
if I were them they came out with a engine after my own spec's. They actually
produced a great engine that would give these 400.00 and 500.00 dollar
engines a run for their money. This was dubbed STS MK11. My drivers have
been testing it and found that it was able to keep up and even surpass
these high dollar Italian engine with the grace of a expensive .21 5 to 8 port
engines and get about 9 minutes of run time doing it.
As I watched the testing this engine had taken a buggy and was pulling wheelies up to 75ft down the straights with a crisp sound that I and you and everyone else
likes to hear at 202 degree temps. I had thought that it was time STS release
these to the market to compete against the ever soaring over priced
Italian engines.
Finally! You to can have this engine and feel the bliss of knowing you got way
more then you paid for and probably for the first time. These engines are
worth every penny. Modified they are off the hook, Smooth, powerful, reliable.
Rick Brake RBMods
I've got gas, and I'm PROUD of it... 1/5th scalers unite!
Kemorc is offline   Reply With Quote
Old 05-30-2007, 02:17 AM   #22
is it possible to just buy a piston for it somewhere, and not the whole set?
Old 05-30-2007, 10:49 AM   #23
Kemorc's Avatar
i can only get you the piston/sleeve. no one sells either separate.
Old 05-30-2007, 01:11 PM   #24
not even from the factory itself?
might ask them
Old 05-30-2007, 02:46 PM   #25
Kemorc's Avatar
you aren't going to find a company or engine manufacturer that sells their pistons separate from their sleeves. It'd be pointless to do so.
Old 06-27-2007, 11:42 PM   #26
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
KemoRC,
Do you know which engine would be better on the STS line for TRUGGIES ?
thanks,
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 06-28-2007, 09:04 PM   #27
Kemorc's Avatar
that depends on your budget AND what your track allows for engines. if you want to go the .21 route, the MKII is the way to run with. If you want to save a little dough and go with a .28 or even a .30, those could very well be up your alley too.
The .28 in a truggy is powerful enough as it is, but i've seen a few .30's floating in a truggy. Jammin jay drove one around, the power band was similar to a light switch... on and off. Truth be told, i think that .30 in that particular video was modded.
Old 07-06-2007, 03:05 AM   #28
EG1
EG1's Avatar
I've popped a few STS cranks, my 21T had the rear bearing fail and that snapped the crank. STS repaired the engine and sent it back, their service is top notch.
I'll be eager to see how the MK II goes...
EG1 is offline   Reply With Quote
Best Pipe for STS d21t mk2 fossman Nitro Off-Road 4 10-31-2007 09:47 AM
sts .21 d21T WHITE LIGHTING Electric Off-Road 1 01-26-2007 08:47 PM
STS D21T & D21B porter Electric Off-Road 31 01-16-2007 01:30 AM
STS D21T buggy engine joeling Electric Off-Road 5 03-07-2006 08:57 PM
STS D21T buggy engine joeling Malaysian R/C Racers 1 03-07-2006 01:47 AM
