Like Tree13Likes
Murnan Modified Motors
Old 10-09-2006, 10:36 PM
  #931
Lil Paul's Avatar
Default Thank YOU!!!
Hey Uriah,
Thank you for getting my motors back to me in a hurry. The Ninja is working out really well. I qualified 1st in the B-Main this past weekend, and went onto bump-up into the A, finished 6th in the A after having broke a steering rod. I would recommend you anytime to someone looking for that extra power in a motor.
Paul (Bruckner Hobbies)
Lil Paul is offline
Old 10-11-2006, 10:11 AM
  #932
Murnan,
What's your thoughts on the longevity of the use of ceramic bearings (rear) in 12 motors vs. .21? More/less reliable---or not reccomended?
Thanks.
1FastVW is offline
Old 10-13-2006, 05:36 AM
  #933
Grinder's Avatar
Originally Posted by 1FastVW
Murnan,
Thanks.
I recomend using high quality ceramic bearings in the rear of both size engines. If the ceramic bearing is of high quality, and the balls are all of perfectly equal size the ceramic will outlast a steel bearing. The problem with some of the ceramic bearings wearing out too fast from the factory is because the balls are not being perfectly matched to eachother, and to the races. I am having this done and I do not see any excess wear problems. I think .12, and .21 are both reliable, and faster with ceramic rear bearings.
Grinder is offline
Old 10-13-2006, 05:55 AM
  #934
rcpanama's Avatar
Grinder I have a Plus 12 3CT by Murnan, can I change the ceramic bearing that came with the Engine with the ones you have for this engine?
RCPANAMA
rcpanama is offline
Old 10-13-2006, 06:31 AM
  #935
itchy b's Avatar
RCPANAMA
wouldnt the murnan motor already have grinders bearings installed
itchy b is offline
Old 10-13-2006, 07:03 AM
  #936
rcpanama's Avatar
When I bought it, he didn't have that option, I have it with the original Ceramic from Novarossi
RCPANAMA
rcpanama is offline
Old 10-14-2006, 05:10 AM
  #937
Grinder's Avatar
RCPANAMA
Sure. I will have ceramic bearing kits availale on my site within 2-3 more weeks. I have to wait until Nova has the bearings.
Grinder is offline
Old 10-14-2006, 05:38 AM
  #938
roadrage's Avatar
Trader Rating: 14 (100%+)
hi grinder. would i be able to tell a differecne with your ceramics in the 12+3 compared to the stock ones?
roadrage is offline
Old 10-14-2006, 07:44 AM
  #939
cdelong's Avatar
Uriah,
Nice to meet you in Cincy. It was surely a great show in the final.
Anyone interested in customer service should be sending their engines his way. My friend bought a few engines and is very pleased. Uriah has not done any work for me (yet), but took a significant amount of his time to answer questions and look at a questionable P/S set I had. I will be doing business in the future for sure.... possibly for the WinterNat's
Corey
cdelong is offline
Old 10-16-2006, 07:13 AM
  #940
Grinder's Avatar
You can see and hear the difference with both bearings being ceramic. The engine spools up very fast. I can feel the difference in the stock bearing vs our bearing, especially with both front and rear being matched ceramics.
Grinder is offline
Old 10-16-2006, 07:21 AM
  #941
Grinder's Avatar
Originally Posted by cdelong
Uriah,
Corey
It was sure nice to meet you too Corey. The final was increadible. Definitely the closest hour long nitro race I have seen. I don't know how they can do it. Drive with that much intensity and focus for an hour. My hat is off to all the guys that made the main. But Mike and Ralph they put it down. They put on the best show I have ever seen. Oh and all that tire dust.
Grinder is offline
Old 10-16-2006, 08:40 AM
  #942
Code:
Thanks.
1FastVW is offline
Old 10-16-2006, 07:43 PM
  #943
mrx
mrx's Avatar
Trader Rating: 19 (100%+)
Hello Uriah,
I have not run any modifed motors but may i ask can a used motor about 2 gallons of 25% fuel through and compression is still good to be modified by you?
What do you suggest.
Thanks.
mrx is offline
Old 10-16-2006, 08:09 PM
  #944
Default Xenon
I have a ABC Xenon and only in the run in process for 6-7 tanks. Can u still modify it for me. If it is OK please let me know and I will send it to you right away. Also can u fit ceramic bearings in them as well?
slide_228 is offline
Old 10-16-2006, 10:53 PM
  #945
Racing4Evo's Avatar
Uriah,
Will you have those special ceramic bearings for the Sirio?
Racing4Evo is offline
