Like Tree13Likes
Murnan Modified Motors
Old 08-22-2006, 06:01 PM
  #871
Trader Rating: 15 (94%+)
Default mega .21 dsII
Hi Uriah
have you done any mods to the mega .21 dsII ?
i just got one of these engines and im yet to run it, i just wanna see what type of power increases this engine can do with mods
thanks
John
mrgsr is offline
Old 08-23-2006, 07:00 AM
  #872
rcpanama's Avatar
Default Difference between plugs
Can some one explain the difference in using a Turbo C" glow plug very cold C8 TGC Novarossi and Turbo F" glow plug extra cold C8 TGF Novarossi and the difference between a short and long plug.
In Panamá we a have a very hummed and hot weather, 80 to 90% humidity and 28 to 34 degree.
RCPANAMA
rcpanama is offline
Old 08-23-2006, 09:30 AM
  #873
XTREMERCHOBBIES's Avatar
Originally Posted by Grinder
I will test the Xenon R this weekend. From the looks of it, I like it. The internals remind me of an RB Novarossi crankshaft with a Sirio twist. The piston/sleeve are both aluminum, and very nice. The rod looks like Novarossi (Heavy Duty).
I am sure the engine will be fast. I will run it this weekend and let you know. Have you tested one yet?
Glad to hear from ya! We have a few Matrix R prototypes arriving next week - RB's personal stash from the euros These protypes will be different from the production model so I have doubts if I'm gonna run mine (will just keep it) We will test one for the shop. Let you know how it goes..
XTREMERCHOBBIES is offline
Old 08-29-2006, 01:54 PM
  #874
Maddin21's Avatar
Default XenonR
Are there any results Uriah?? Did you test different pipe combinations too??
YES,YES,YES...it's the engine of my choice for the rest of the year and 2007...
I raced it first at the german champs...a high speed track...and it is fast
Fuel consumption is very low...the huger the track, the better the runtime compared to other top-engines...
Carb setup is quite easy...
I used the JP2031 with 41016 mainfold (middle)...and will get the new 2013 incl. conical mainfold next week...
MADDIN
Maddin21 is offline
Old 08-29-2006, 02:09 PM
  #875
Fsturbo15's Avatar
RCPANAMA
F= Freddo(cold)
C=Caldo (hot)
http://www.rbproducts.com/mainEn.php...ght%20glowplug
Fsturbo15 is offline
Old 08-29-2006, 02:12 PM
  #876
Grinder's Avatar
MADDIN
Hi. Yes I ran the Xenon R this past weekend. The engine is fast.
Fuel consumption is also great!
I initially tried the engine with a Novarossi 2052 with long conical. With this combo the engine was fast.
I tried the Sirio 2013 pipe and conical header combo, and WOW. This combo made the engine really wake up.
I made a few modification to the engine after initial testing, and the mods made the engine faster, and gave it a much angrier note.
I will have a review of the engine and the performance before and after the modification on my website by the end of the week. Stay tuned.
Grinder is offline
Old 08-29-2006, 02:32 PM
  #877
Maddin21's Avatar
...puuhhh, three more days...
The 2013 in non-conical version was tested by a team-mate, but he was not happy with that...but the conical version really seems to work!! I heard that several times... I orderd two...you never know...HAHA
My XenonR loves to be rich low-end...but there is only a small step to be too rich...maybe a hotter plug will solve that...
---MADDIN--
Maddin21 is offline
Old 08-29-2006, 04:34 PM
  #878
Grinder's Avatar
---MADDIN--
Yes, a few more days. hehe
Great input Maddin21 keep it coming. 2 minds are better than one! I too found that the low end is sensative to being too rich, or not. I kept leaning the bottom, until I got rid of that low end rich bog off of some of the corners. After I got the engine fully broken in and leaned, no more rich bog. Good idea to get 2 of those pipes. I also like this pipe with the Nova +35. I just hate when your favorite pipe gets smashed, and it's the only one.
Grinder is offline
Old 08-29-2006, 04:37 PM
  #879
afm
afm's Avatar
Originally Posted by Fsturbo15
The numbers and characters on the plugs, are the product number, wire thickness, and thermal range of the plug’s body. Example: The Novarossi C6TG (F) or (C)
Product: C (Conical)
Wire Thickness: 6
Plug Type: T (Turbo)
Plated: G (Gold)
Thermal Range: F (Fredda = Cold) C (Calda = Hot)
The plugs with cold thermal range F (Fredda), have a body with thinner walls and shorter body, so they dissipate heat better and faster to the engine head. The plugs with hot thermal range C (Calda), have a body with thicker walls and longer body, so they dissipate heat better and faster to the engine head. The number of threads is the same on both types of plugs.
How to select the proper plug:
·When the ambient temperature is high, we have to use a plug with thicker wire.
·With higher compression, we have to use a plug with thicker wire.
·Humidity determines if we use a Cold (F) thermal range, or Hot (C) thermal range.
·With high humidity percentage we should use a Hot (C) thermal range plug.
·If we have high temperature and high humidity, we should use a plug with thick wire and a Hot(C) thermal range.
AFM
afm is offline
Old 08-29-2006, 04:38 PM
  #880
mugendude's Avatar
is the xenon faster then the 35 plus
mugendude is offline
Old 08-29-2006, 05:26 PM
  #881
quietstorm76's Avatar
Hey Grinder did you get to check out the performance of the DSII on Sunday that Winner's Circle was running? If so what did you think?
quietstorm76 is offline
Old 08-29-2006, 08:40 PM
  #882
wizby's Avatar
I have to tell everyone my murnan mega .12 is a absolute rocket. Great fuel mileage and almost too much power. The man is an artist.
wizby is offline
Old 08-30-2006, 05:32 AM
  #883
Grinder's Avatar
Wire Thickness: 6
Plated: G (Gold)
AFM
Thanks AFM. Perfect!
Grinder is offline
Old 08-30-2006, 05:34 AM
  #884
Grinder's Avatar
Grinder is offline
Old 08-30-2006, 05:35 AM
  #885
Grinder's Avatar
I did see the engine running. Looks pretty good for a stock engine.
Not sure which pipe he was using though.
Grinder is offline
