Like Tree13Likes
Murnan Modified Motors
Old 02-21-2006, 07:10 PM
  #676
bcquick's Avatar
Red face
Yes gary i still do and will be running his rer at kissimee,
as i dont think the os will like that mile long straight.
but i might need the fuel millage the murnan os should supply me with along with the extra power over a stock one.
stop starting trouble lol
bcquick is offline
Old 02-22-2006, 04:30 AM
  #677
TrickPonYracing's Avatar
i think your right fuel milage will be something we will all be after i know i will have to change motors to........ maybe we should be pushing for three speeds... see you there. me start trouble
TrickPonYracing is offline
Old 02-22-2006, 04:47 AM
  #678
hey murnan do you rebalance crank after mods?
XingXing is offline
Old 02-22-2006, 04:51 AM
  #679
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Yes, sedan.......I was running .3mm of shim on the .12.
rcfoolz is offline
Old 02-22-2006, 08:05 AM
  #680
Grinder's Avatar
Of course.
Grinder is offline
Old 02-22-2006, 10:11 AM
  #681
rbboy's Avatar
hi uriah! what is the best pipe that you recommend to be used on your engines
rbboy is offline
Old 02-22-2006, 06:28 PM
  #682
GABOS's Avatar
Grinder, I send you a private message, Iam interested in buying an engine can you send me a PM, thanks
GABOS is offline
Old 02-24-2006, 04:19 AM
  #683
Default Crankshaft silicone
Originally Posted by areal
I already knew it was going to be difficult to get a straight answer
Nevertheless your tips and tricks showed me the way!
Thanks!!!
PS: If I eventually manage to drill the crankshaft, I'll let you know
As promissed, I'll let you know how this is going.
I finally managed to drill an old Mega ZX21 crankshaft.
I had a hard time finding the proper carbide bit (on the other side of the Atlantic getting a carbide bit is a pain in the $ss) but I eventually managed to do it. I worked out pretty good.
After drilling and cleaning the crankshaft I tried to fill the hole with high temp RTV silicone (I'm using high temp silicone from Wurth - used in 1/1 engine gaskets) but I had a hard time making it smooth. It just doesn't look like the ones from the engine manufacturers.
Maybe you guys (Grinder, TheDoctor and nitrodude) can share your tips on how to insert the silicone and making it smooth?
Thanks for your help!
PS: I'll try to post a pic later today!
areal is offline
Old 02-24-2006, 05:32 AM
  #684
Grinder's Avatar
I like the Skyline VR12, Mugen Shimo, and JP. They are all very good. The VR12 gives the most power for fuel consumed.
Grinder is offline
Old 02-24-2006, 05:49 AM
  #685
Grinder's Avatar
Try not to overfill with RTV. Make the first application and smooth it with a flat blade that is rounded to match the inside of the crank. and some oil, then leave it alone. If you keep messing with it trying to make it smooth, it will only get worse. When it is smooth dry the oil with a cotton tip. It takes a lot of trial and error. Also make sure that the silicone is not the highest point, in other words make the fuel hit the metal and then smoothly flow to the silicone. If you do not the fuel can eventually work it's way underneath the RTV and make it detach.
The Mega has insane torque when lightened, but loses even more of it's reliability. Make sure you keep good rods in it.
Grinder is offline
Old 02-24-2006, 06:13 AM
  #686
Thanks Grinder!
I'll try to fill it the way you explained.
As you can see from the pics, the silicone is not that good
Attached Thumbnails Murnan Modified Motors-cambota1.jpg   Murnan Modified Motors-cambota2.jpg
areal is offline
Old 02-24-2006, 12:43 PM
  #687
robert maestrey's Avatar
Thanks Grinder!
Yikes never learn unless you try......
robert maestrey is offline
Old 02-24-2006, 01:29 PM
  #688
here's a tip ... i used the top of a sharpie marker and cut it to fit and i use mek. instead of oil to make it smooth.. just a though
Old 02-24-2006, 06:59 PM
  #689
JustRace's Avatar
what is mek?
JustRace is offline
Old 02-24-2006, 07:47 PM
  #690
Data's Avatar
Originally Posted by JustRace
what is mek?
methyl ethyl ketone, i think.
Data is offline
