Like Tree13Likes
Murnan Modified Motors
Old 05-16-2012, 10:47 AM
  #3166
Grinder's Avatar
Originally Posted by D-nicest
The Murnan Reds M3T is definitely one hell of a beast, I can say that from first hand experience. It also helped me win the Kosmic Shootout in BD Delaware. Thanks for the heat Uriah
Nicely done Diatta.
Grinder is offline
Old 05-17-2012, 10:02 AM
  #3167
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Thanks!
ToysRUsKid is offline
Old 05-20-2012, 11:51 PM
  #3168
Black niNja's Avatar
Originally Posted by Grinder
Hi. Yes, we have tried them. They are really good. Very durable compared to past Novarossi plugs.
After break in I do suggest running the C8TGH plugs in most on road .21 engines, in most conditions. They work great!
Hi Uriah, can I use C7TGC / C8TGC plugs for my .21 on road? I couldn't get C8TGH/F in my area. Your advise needed thanks.
Black niNja is offline
Old 05-22-2012, 07:09 AM
  #3169
Grinder's Avatar
That would not be ideal. The c plugs are for offroad. To run them in an on road car you must run the engine very rich.
Try to get the c8tgh, or c9tgh. If you can't find them locally, I stock them.
The c8tgc would be the best of the plugs you have.
Grinder is offline
Old 05-26-2012, 06:43 PM
  #3170
5crossyourlip's Avatar
Trader Rating: 28 (97%+)
what is a good tolerance on the rod before it needs to be changed on the m21...i have about 1 1/2 gallons after break in and the temp never got over 240
5crossyourlip is offline
Old 05-26-2012, 07:14 PM
  #3171
Grinder's Avatar
The M21 rod should be changed every 2.5 gallons. They will not show much stretching, but will fatigue. It will probably break in the middle of the rod, not at the bushing.
Grinder is offline
Old 05-26-2012, 07:20 PM
  #3172
Old 06-04-2012, 12:37 PM
  #3173
ToysRUsKid's Avatar
Uriah, sent you a PM
Old 06-05-2012, 11:41 AM
  #3174
Grinder's Avatar
Default Congratulations Team Murnan
Congratulations to Neal King. He won the BRCA round 4. He raced the Murnan Modified M21 engine.
Here is the story from RedRC.
http://www.redrc.net/2012/06/neal-ki...brca-18th-rd4/
Grinder is offline
Old 06-05-2012, 09:50 PM
  #3175
FaanP's Avatar
Mr M,
Thanks for the motor, it looks awesome. Starting the run in procedure this weekend. (I hate this part of the hobby .....)
Just a quick question if I may .... What is your opinion on the OS 2080 pipe and header. With motors does work really well and what kind of perforamance does it give in general ?
Thanks for all your help and support.
Faan
FaanP is offline
Old 06-10-2012, 06:11 AM
  #3176
Grinder's Avatar
Originally Posted by FaanP
Mr M,
Faan
I have heard good things about the 2080 on the M21. I have. It tried it yet.
Grinder is offline
Old 06-11-2012, 05:45 AM
  #3177
Grinder's Avatar
Default Murnan Modified M21 is Texas Biggie Champion
Congratulations Terry Brown. He won the Texas Biggie using the M21 engine. Here is the story.
http://www.murnanmodified.com/newsde...9f436087d3c6ba
Grinder is offline
Old 06-12-2012, 02:05 AM
  #3178
Default Attention Grinder
just put in a new sleeve piston and connecting rod can't get the motor to spin past the pinch tried heating the motor with a heat gun and still can't get it to spin and when it does it stop with the piston stuck in the pinch. i have let the heat gun sit on the motor for better the hour and it still gets stuck i spent at lease three hours trying to get this motor to start. whats the problem? something just don't seem right i never had this much of a problem with a new motor. Grinder i brought the sleeve,piston and rod from you i talked with you over the phone about this and tried to get the motor 300 degrees with the heat gun the most i could get was 200 degrees please help. i am at the point where i want to take a torch to it i bet that would open the sleeve "ha ha" please help
bigtee is offline
Old 06-12-2012, 05:17 AM
  #3179
Grinder's Avatar
Hmmm. My heat gun will get the engine well over 300 degrees in less than 20 seconds. 200 degrees may not be warm enough. I usually heat my new Novarossi based .12 engines up to around 250, then let them cool to around 220 before I start them. Some of the Novarossi .12 based engines require a little more heat to get rid of that metal pinch
Make sure you have the .3mm shim under the button. Although the engine will still be able to turn over without the shim, it makes it easier with.
If you still have problems, I can break it in for you.
I'm sure you just need a little more heat to get it started for the first couple of times. The Novarossi/RB Piston/Sleeves are very tight when new.
Grinder is offline
Old 06-12-2012, 06:42 PM
  #3180
went out brought a new heat gun that did the trick. thanks
bigtee is offline
