-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   fuel pressure problem (https://www.rctech.net/forum/onroad-nitro-engine-zone/159981-fuel-pressure-problem.html)
32819toon 05-05-2007 01:42 PM
Originally Posted by dj apolaro
Not sure if this question has been asked, but it could be the pipe. I have seen new pipes defective from the start. They do not create back presure so some reason. Maybe just try another pipe to see.
Hi DJ, interesting comment. What I have noticed is that fuel runs through the fuel pipe from the exhaust and back into the tank. Is this the sort of thing you mean ?
Thanks for the help
Team Kamikaze 05-05-2007 01:44 PM
Originally Posted by 32819toon
UPDATE
The problem appears to be the fuel line between the tank and the carb. I can get fuel into the engine, but as soon as I stop priming, the fuel runs back down the pipe.
Also, I don't know if it's connected, but there was a puddle of fuel on the chassis. It would appear that fuel is leaking from the pipe connection to the tank even though I have it fixed tight with a cable tie. Is there a better way of securing the fuel pipe ?
Thanks for your help guys.
regards,
32819toon
I think it is obvious that your problem of loosing pressure is the fuel line leak, I suggest you use a good quality Fuel line/tubing which will eliminate the leaking problem, some cheap fuel lines just won't hold up, find Dubro brand they are guaranteed good quality.
dj apolaro 05-06-2007 07:19 AM
Thanks for the help
It is possible. It is easy to see, just put another pipe. If it does not work than try other possibilities. Could be fuel tubing, fuel tank, etc.
DJ Apolaro
