Old 09-15-2010, 12:23 AM   #631
From what I heard the evo4 was designed for 7 minute racing where they have a compulsory pit stop in qualifying, so the engine has more power but is alot thirstier as a consequence, think the guys in uk were still using the evo3
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 10-10-2010, 08:18 PM   #632
wingracer's Avatar
Trader Rating: 24 (100%+)
Can anyone else confirm this?
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-11-2010, 01:12 PM   #633
ugglasdav's Avatar
Default evo 3 vs evo 4 .21
does anyone know the main differences between the evo 3 and evo 4 on its power band and run time
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 10-11-2010, 02:01 PM   #634
The sleeve timing is slightly different the the EVO3 also the case volume changed. They built the engine to give a better mid to top speed without losing bottom end power the engine was known for. Fuel use is hard to say because the finger on the throttle determines fuel consumption as well as clutch and all the other variables. Picco has not released a 9 port for the fuel consumption reasons. There are also 2 versions of the EVO4 other then the newest that has the short heatsink and combustion chamber combo.
xspower is offline   Reply With Quote
Old 10-12-2010, 03:13 PM   #635
ugglasdav's Avatar
anyone know the differences??
>>>Sanwa m11x
Old 10-12-2010, 03:52 PM   #636
The fuel consumption is listed above the issue with answering the "power Band" question you are asking is that the pipe makes the difference where and when the engine hits. The power band generically stated is slightly higher on the 4 then the 3. That would be all I would speak until I knew what pipe you are running. The engines 3 or 4 do not run like a Nova. The Nova's for the most are mid to top with little on the bottom compared to the Picco. The Picco is more Mid bottom with the pipe changing the Top dramatically. And again fuel consumption depends on the pipe. The more top you get out of the engine the more fuel it is going to burn. That is why 9 ports show slightly higher top speeds and less fuel mileage. Where the 7 ports have slightly lower top and better mileage.
Old 05-08-2011, 11:28 AM   #637
quietstorm76's Avatar
Default 2011 IDM "Torque" base
I just want to let everyone know that the NEW 2011 IDM .21 and .12 are really good. Stock and the Mod version are very powerful and durable. Not to sound like I'm advertising because I get nothing out of this but if you are looking to buy a new engine I would consider the IDMs or the Picco Torque versions. Anyone else running the new IDM?
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 05-08-2011, 11:39 AM   #638
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
did you forget to mention the 35plus you blew the doors off few weeks back ....but im sold i really want one
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 05-08-2011, 11:39 AM   #639
MugenDrew's Avatar
Trader Rating: 30 (100%+)
I have been kicking the idea around since running with ya at Kraceway. Finally got off my arse (that means made the time) and got in contact with Jerry.
What pipe&header, fuel and plug are you running in your 1/8th?
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 05-08-2011, 07:43 PM   #640
What's up man? I'll see you soon Anyway I ran 2015 pipe/short header, IDM T7 plug and Byrons 25%/11%. Head shims @ .6mm. The motor is great, easy tuning and runs cool. I think I was running about 230 most of the and the highest temp all weekend was about 250 but that was on any empty tank. After running the IDM .12 the last to weekends I'm sold.
Primary Weapon: ?
Secondary Weapon: ?
Old 05-09-2011, 06:26 AM   #641
Grinder's Avatar
I was able to run over 5 minutes with my modified IDM EVO4 .21 at my home track. I was able to get just under 5 minutes at the Worlds track in Homestead. My modified IDM EVO4 was doing 70+ MPH down the Homestead straight.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 05-09-2011, 07:52 AM   #642
G87z's Avatar
I am also running the New IDM .12. Great engine!
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 05-10-2011, 10:56 AM   #643
hi Quietstorm..the 2015 pipe u mentioned..are u referring to the Nova 2015 pipe?or Picco has the same numbered pipe?
tq23 is offline   Reply With Quote
Old 05-10-2011, 11:00 AM   #644
It's the Nova pipe/header. I will be running the 2033 from now on though because I feel the 2033 Picco pipe is a better match.
Primary Weapon: ?
Secondary Weapon: ?
Old 05-10-2011, 11:02 AM   #645
Yeah I heard you were running one. What pipe are you using? I have the IDM 2617 and it hauls azz
Primary Weapon: ?
Secondary Weapon: ?
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
cen products chifan26 Nitro On-Road 7 09-19-2005 02:50 PM
