Old 10-07-2009, 11:37 PM   #601
Team Kamikaze's Avatar
Originally Posted by shokyo View Post
did anybody here tried use LRP piston and sleeve in their IDM .12...???
where should i get piston & sleeve replacement for IDM .12 around asia....i'm from malaysia.
cheers ;o)
You can buy it from Hong Kong, Hobby Pro sells it.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-08-2009, 12:14 AM   #602
NitroWD's Avatar
cheers ;o)
i've tried a LRP p/s in a IDM, no issues encountered so far.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 10-08-2009, 02:25 AM   #603
shokyo's Avatar
how many shim did u used at turbo head...???
i got problem using LRP p/s....its shorter than previous IDM sleeve..???
FB= Yuneef Shokyo
~///~ Futaba 3PDF FM 75.67Mhz + Futaba 3PKS 2.4 GHz ~///~
~///~ Mugen Seiki MTX-4R + LRP spec 3 je(dah jual), STS DX3R, OS SPEED TUNED (dah barai),Picco edo (dah barai), Picco IDM (dah barai), Nova Max (dah jual), Nova NS3,Nova 353 09, Nova .12 3ST 09 ~///~~///~ Serpent 960 + Nova Flash .21 ~///~
shokyo is offline   Reply With Quote
Old 10-08-2009, 03:57 AM   #604
NitroWD's Avatar
which LRP spec did you used? mine's the LRP spec3 p/s fitted to the IDM evo3...with 0.5 total shims for 25%.
from what i know only LRP spec3 and spec4 is similar to IDM evo3.
Old 10-08-2009, 04:52 AM   #605
Just for some info the piston/sleeve set for the IDM is the same part number for the EVO3 and the EVO4 I would assume that the only difference is that the modifications are not the same if there are any on the LRP.I have not seen one. Also there is a difference in the piston/sleeve sets between the EVO2 and EVO3 .21 engines that are labeled spec 2. They both will run but the Spec II piston/Sleeve is slightly different. Just some info.
so here is a list for the IDM brand
for the .12 EVO3,4 the same
for the .21 EVO2 and old NON SPECII EVO3 same
EVO3 .21 new part number
xspower is offline   Reply With Quote
Old 10-10-2009, 09:11 AM   #606
Default IDM 2607 p1 7355 pipe set
Is the pipe still made? If so where can I get 1?
Smokinnitro is offline   Reply With Quote
Old 10-10-2009, 11:36 AM   #607
I do believe that the pipeset was discontinued. I have not ordered anything but the 2617 and the 2651 for the last orders placed. I think that we still have a few in stock. Get with Lee at Winners circle he may have one. Or can get it for you.
Old 11-01-2009, 10:19 AM   #608
speedoutlaw's Avatar
Default idm products
at the last race i ran the EVO 4 at the SOUTHWEST CHAMPIONSHIP series race and man was on fire. out of corners and still accelerating at the topend of the straight away. the 2607 is good and was impressed with the 2617. and so not to say anything more about the EVO 4 it speaks for it self. EVO 4 took 1st overall at the regionals. Thanks to Jerry at TeamXspower and IELASI DANIELE MOTORSPORTS
___________________________________________________________________________
Sponsors;* TEAM SERPENT AMERICA* *733 *---*o.s.engines - * FUTABA RADIOS*--*TWISTER TIRES*---*MAXY'S PRO RACING FUELS*-- ---*TEAM SPIDER*--
speedoutlaw is offline   Reply With Quote
Old 11-02-2009, 03:36 AM   #609
rcabj's Avatar
Default idm evo4
guys , first time for me with either picco or idm base motors. yesterday was it's maiden race. after breaking / running it like the manual 15-20 minutes ( took me only the second crank to get it going) . just a day b4 the race i started to tune it to racing pace. to be on the safe side it was still a bit richer. the track is a small one and technical with lots of tight corners.( the straight was around 140ft). anyway i feel very good since i really didn't want to lean it out too much. the bottom was good, and mid to top was out of this world
i paired it with the 2617, 16 % fuel, no 6 glowplug. also kept the standard head shim.
and the best thing of all is the runtime was more than 7 minutes. it was idling all day long too. can't wait to see how it goes in a larger track end of this month....
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 11-02-2009, 03:53 AM   #610
M7H
M7H's Avatar
It is allowed to turn of the engine between runs...
Serpent
M7H is offline   Reply With Quote
Old 11-02-2009, 06:47 PM   #611
rcabj's Avatar
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 11-17-2009, 06:30 PM   #612
GMartinez's Avatar
Trader Rating: 85 (100%+)
Jerry when is the 2 new product lines due out
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 11-17-2009, 07:21 PM   #613
The pipesets are here just out of the 2617 now. The 2651 we have in stock.
Old 11-23-2009, 02:31 AM   #614
rcabj's Avatar
Default holding the tuning
hi guys..yesterday was the 2nd race with this idm evo4, i put in a new glow plug early in the morning before race start. so the first heat went well.
but the 2nd and 3rd heat was a blunder...it was acting wierd as if the tune was way off...but at the end of the day in the 20 minute main final it seems to hold the tune well except 2-3 minutes before the race ended i heard my second gear shifted a bit later. there's no issue with power and runtime but i was wonderin if this motor too sensitive to weather changes and cannot hold its tune.
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 11-23-2009, 09:05 AM   #615
That sounds about right, I have had a heck of a time getting my evo4 broken in. I have run nearly 2 gallons and the engine still sticks at TDC while cold. The tune doesn't drift much though, I can usually go out 2-3 days without moving the HSN more than an hour or two.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
cen products chifan26 Nitro On-Road 7 09-19-2005 02:50 PM
