Old 08-11-2009, 11:42 AM   #586
Is Idm distributing its own version of the picco 2651 pipe? If so what is the part number?
jiggamacdaddy is offline   Reply With Quote
Old 08-11-2009, 09:36 PM   #587
2651 kit pipa is what the sticker says on the side (yes spelled like that)
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 08-16-2009, 08:21 PM   #588
keavze's Avatar
Default IDM plugs
it was stated somewhere here that the correct plug to use is IDM6 for .12and IDM7 for .21...
anyone tried using IDM7 in their .12?
for 25% nitro, 90F and 80% humidity
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 08-17-2009, 01:17 PM   #589
You can run the number 7 may be a little cold not want to idle real well or low speed. it will run but the 6 is a better choice and with the humidity add a shim if you wish, You should based on the 25% you are running.
xspower is offline   Reply With Quote
Old 09-04-2009, 11:11 AM   #590
VIPMOTORSPORTS's Avatar
Originally Posted by xspower View Post
The Spec 2 .21 has a slightly different piston/sleeve set the location of the wrist pin is different then the original case for the EVO3 also the new runs have a new carb completely this was a running change in the line. Now as the carb changed on the .21 they have also changed on the .12 as well. They have a steel slide as well as the other changes mentioned in the above post with the plastics and such. There is not a Spec2 EVO3 .12 though. At least that I have seen here in the states.
Jerry how can I get one of these new carbs??? The one on my evo3 is constantly giving me problems...
Motonica-USA // Novarossi // TKO Bearings // Airtronics // Protoform
VIP Auto Group Inc.
VIPMOTORSPORTS is offline   Reply With Quote
Old 09-04-2009, 03:57 PM   #591
You can call Jesse at Beltran or Lee Muse at Winner's circle. We have them in stock.
Old 09-22-2009, 05:27 AM   #592
Hi there,
could someone confirm that the Picco P7TC plugs are as good as the official IDM plugs in a .21 Evo 3 IDM? The filament in the P7TC plug is deeper in to the plug body/more recessed than those in the IDM plugs for some reason.
Also, when I last opened the engine I noticed that the top bushing of the (P7) conrod had moved laterally - partially out of the top of the conrod and across the wristpin. Could anyone tell me if this is due to excessive wear or a vibration coming from somewhere else in the engine?
Thank you!
Ian C is offline   Reply With Quote
Old 09-22-2009, 05:54 AM   #593
Send a message via MSN to PMSorber
Originally Posted by Ian C View Post
Hi there,
Thank you!
1) No they are not.
2) I have seen this once before, in this case it was due to vibrations.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 09-22-2009, 05:58 AM   #594
M7H
M7H's Avatar
Hi there,
The IDM plugs a made by Sirio, that's why they look different.
But yes, you can use the Picco plug offcourse.
But, last year the Picco plugs had problems, that's why I stepped away from them and went to GRP plugs.
Replace the rod immediately, don't run the engine like this, because the 2 lubrication holes are blocked now.
I heard there was a batch of Picco conrods having this problem, it's been adressed and solved now, but you have 1 of these rods (I probably do also, but haven't discovered yet which one of my 4 engines have a problem)
Serpent
M7H is offline   Reply With Quote
Old 09-22-2009, 12:03 PM   #595
nazwenhome's Avatar
Trader Rating: 33 (97%+)
idm evo3 with #7, lower temp, better mileage and not easy to tune bottom needle. using 25% tornado, at 90% humidity, about 90F.
Serpent S411 TE : ready to race
Tamiya TA05 VDF : sleeping mode
Align 450 sports v2 : tick-tock in progress
nazwenhome is offline   Reply With Quote
Old 09-22-2009, 03:47 PM   #596
Actually they are not made by Sirio anymore. Just some info they were but not now.
Old 09-22-2009, 04:51 PM   #597
M7H
M7H's Avatar
Aha, ok...
Nice to know...
i don't really care who makes them, as long as they are of GRP quality!
Atleast, the GRP plugs from last year, the last GRP plugs seem to be of a lower quality...
Serpent
Old 09-23-2009, 02:39 AM   #598
Aha, ok...
Nice to know...
New developments are taking place, cannot disclose to much about this. Due to the exit of GRP and the move from Sirio (also partly due to exit) it is needed to have again a superb glowplug. By the way, the plugs are / where not manufactured by Sirio... only traded by. They are / where made by an American company.
@ConSult Trading
Old 09-23-2009, 05:06 AM   #599
Hi there,
Thank you!
When the top bushing on the rod has moved from the actual rod assy itself it is usually caused by vibration from either the rear bearing beginning to go bad, and also overrevving I have seen this as well. And also a lack of lubrication will also cause this as the wrist pin has a very tight tolerance to the bushing and this will also affect it. I am sure if you are using a good fuel this is not the case. If the top bushing has moved check the rear bearing also check the sleeve for damage in the ports. Make sure the vibration from the bearing has not damaged anything else. If you need to know how to check the rear bearing correctly PM me and I will explain so you are good to go.
Old 10-07-2009, 11:11 PM   #600
shokyo's Avatar
did anybody here tried use LRP piston and sleeve in their IDM .12...???
where should i get piston & sleeve replacement for IDM .12 around asia....i'm from malaysia.
cheers ;o)
FB= Yuneef Shokyo
~///~ Futaba 3PDF FM 75.67Mhz + Futaba 3PKS 2.4 GHz ~///~
~///~ Mugen Seiki MTX-4R + LRP spec 3 je(dah jual), STS DX3R, OS SPEED TUNED (dah barai),Picco edo (dah barai), Picco IDM (dah barai), Nova Max (dah jual), Nova NS3,Nova 353 09, Nova .12 3ST 09 ~///~~///~ Serpent 960 + Nova Flash .21 ~///~
shokyo is offline   Reply With Quote
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
cen products chifan26 Nitro On-Road 7 09-19-2005 02:50 PM
